Execute code if Blynk is not connected
Hello, good morning guys
I would appreciate if you could help me with this code, there will be some way this code works if you are not connected to Blynk and searched but nothing else and I have seen nothing else with esp8266 but I am using an Arduino R3 and a bluetooth module HC05
SoftwareSerial SerialBLE(10, 11); // RX, TX
void led();
  SerialBLE.begin(9600);
  Blynk.begin(SerialBLE, auth);
void led() {
  digitalWrite(5, HIGH);
  delay(100);
  digitalWrite(5, LOW);
  delay(100);
some code is missing !
char ssid[] = "***********";
char pass[] = "*********************";
//etc...
Blynk.begin(auth, ssid, pass, server_ip, port);
But that would be if I used a Wi-Fi connection, but I’m using an Arduino and a Bluetooth module HC05
No habia visto un error en mi codigo
void led();
  pinMode(5, OUTPUT);
void led() {
  delay(100);
  delay(100);
I’m not familiar with Bluetooth myself but generally this would be sorted by handling the connection manually by replacing Blynk.begin(SerialBLE, auth); with Blynk.config somehow
But you do not have to start Blynk through that line
On WiFi world, and I believe the flow for Bluetooth would be the same, you can manage the connection yourself and use Blynk.config(auth); instead of Blynk.begin more info here: Blynk.config
I can’t help you as I never used Bluetooth with blynk.
:wink:
