Example sketch won't compile
I just installed the blynk library and tried using the provided example sketch for CC3000 wi-fi shield. Unfortunately, the example sketch won’t even compile.
Compiler gives the following error:
The sketch CC3000:50: error: ‘Blynk’ was not declared in this scope
The blynk library appears in arduino IDE library menu, so it should be accessible, right?
I’m not advanced enough to know how to debug the provided code. Any suggestions?
I’d like to try using blynk, but I’m uncharacteristically stuck on step 1.
Share your code please, your setup. We need more details )
Resolved the problem myself, but thanks for the quick response. Loving the product so far!
