Hi, can someone give a hint that what is the important setting for android phone to let eventor widget work well even when the blynk app is off? Current situation is that, the widget trigger notification only when blynk app is open, but not work when blynk app is close.
The notifications should work regardless if the app is open or not. The only thing that may change is the amount of delay before you receive the notifications. This delay can be reduced by setting the priority to high in the notification widget, at the cost of increased battery usage.
One thing to note is that the project must always be running. (see #6 HERE)
