Even debug
I’m using the 0.3.4 library and log is as follows:
[0] Blynk v0.3.4
[0] Using static IP
[1300] My IP: 193.206.154.114
[5001] Connecting to blynk-cloud.com:8442
[24295] <msg 2,1,32
[29298] Connecting to blynk-cloud.com:8442
[29392] <msg 2,1,32
[29424] >msg 0,1,200
[29425] Ready (ping: 31ms).
[29437] <msg 17,1,96
<ver.0.3.4.h-beat.10.buff-in.256.dev.Arduino.cpu.ATmega328P.con.W5100.build.Jul  5 2016 11:26:03.
[29563] <msg 16,2,0
[29593] >msg 0,1,200
[29615] >msg 20,2,6
>vw.0.0
[32584] <msg 20,2,6
<vw.5.0
[32586] >msg 20,2,6
>vw.1.0
[35584] <msg 20,2,6
<vw.6.0
[35586] >msg 20,2,6
>vw.2.0
[38584] <msg 20,2,6
<vw.7.0
I tried to install the new version 0.3.7 and the log is much less readable.
[0] Blynk v0.3.7 on Arduino Uno
[0] Using static IP
[1300] IP:193.206.154.114
[5895] <[02|00|01|00]
[5896] <...............................
[5928] >[00|00|01|00|C8]
[5928] Ready (ping: 31ms).
[5953] <[11|00|01|00]d
[5978] <ver[00]0.3.7[00]h-beat[00]10[00]buff-in[00]256[00]dev[00]Arduino Uno[00]cpu[00]ATmega328P[00]con[00]W5100[00]build[00]Jul  5 2016 11:53:47[00]
[6136] <[10|00|02|00|00]
[6167] >[00|00|01|00|C8]
[6193] >[14|00|02|00|06]
[6217] >vw[00]0[00]0
[9163] <[14|00|02|00|06]
[9164] <vw[00]5[00]0
[9166] >[14|00|02|00|06]
[9174] >vw[00]1[00]0
[12163] <[14|00|02|00|06]
[12164] <vw[00]6[00]0
[12166] >[14|00|02|00|06]
[12176] >vw[00]2[00]0
[15163] <[14|00|02|00|06]
[15164] <vw[00]7[00]0
[15166] >[00|00|02|00|08]
[15176] >[00|00|02|00|08]
[15204] >[00|00|02|00|08]
Why this change that reading gets worse?
Sorry, we don’t provide such kind of support. If you want to change the format - the library is open-source and you can change it.
This is not considered a bug or a problem.
Thank you for your availability…
No problem, please ask if you have any other questions!
what library / file I have to go and change the formatting?
Probably here: https://github.com/blynkkk/blynk-library/blob/master/Blynk/BlynkDebug.h#L130
