BLYNK
ESPAsync_WiFiManager for SP32/ESP8266
arduino-library-badge GitHub release GitHub contributions welcome GitHub issues
Why do we need this Async ESPAsync_WiFiManager library
  • Using asynchronous network means that you can handle more than one connection at the same time
  • You are called once the request is ready and parsed
  • When you send the response, you are immediately ready to handle other connections while the server is taking care of sending the response in the background
  • Speed is OMG
  • Easy to use API, HTTP Basic and Digest MD5 Authentication (default), ChunkedResponse
  • Easily extensible to handle any type of content
  • Supports Continue 100
  • Async WebSocket plugin offering different locations without extra servers or ports
  • Async EventSource (Server-Sent Events) plugin to send events to the browser
  • URL Rewrite plugin for conditional and permanent url rewrites
  • ServeStatic plugin that supports cache, Last-Modified, default index and more
  • Simple template processing engine to handle templates
To appreciate the power of the ESPAsyncWebServer and underlying Async libraries, please compare the more efficient Async_ESP32_FSWebServer example example with the complicated twin ESP32_FSWebServer.
Major Releases v1.1.1
  1. Add MultiWiFi feature to auto(Re)connect to the best WiFi at runtime
  2. Fix bug, typo and minor improvement.
  3. Completely enhanced examples to use new MultiWiFi feature.
  4. Add setCORSHeader function to allow configurable CORS Header. See Using CORS feature
  5. Bump up to v1.1.1 to sync with ESP_WiFiManager v1.1.1.
Releases 1.0.11
  1. Initial coding to use ESPAsyncWebServer instead of (ESP8266)WebServer.
  2. Add more features and error checking to many examples.
  3. Add example Async_ConfigOnDRD_FS_MQTT_Ptr
  4. Bump up to v1.0.11 to sync with ESP_WiFiManager v1.0.11.
This library is based on, modified, bug-fixed and improved from:
  1. Tzapu's WiFiManager
  2. Ken Taylor's WiFiManager
  3. Alan Steremberg's ESPAsyncWiFiManager
  4. Khoi Hoang's ESP_WiFiManager
to use the better and faster asynchronous ESPAsyncWebServer instead of (ESP8266)WebServer.
This is an ESP32 / ESP8266 WiFi Connection Manager with fallback Web ConfigPortal. This Library is used for configuring ESP32, ESP8266 modules’ (WiFi / Dynamic) Credentials at runtime. You can also specify static DNS servers, personalized HostName, fixed or random AP channel. Now with CORS feature.
Thanks to this ESPAsync_WiFiManager library is based on and sync’ed with ESP_WiFiManager, all the features currently supported by ESP_WiFiManager will be available. Please have a look at ESP_WiFiManager for those too-many-to-list features.
First, how Config Portal works?
In Configuration Portal Mode, it starts an access point called ESP_xxxxxx. Connect to it using the configurable password you can define in the code. For example, your_password (see examples):
// SSID and PW for Config Portal
String ssid = "ESP_" + String(ESP_getChipId(), HEX);
const char* password = "your_password";
After you connected, please, go to http://192.168.4.1, you’ll see this Main page:
Select Information to enter the Info page where the board info will be shown (long page)
or short page (default)
Select Configuration to enter this page where you can select an AP and specify its WiFi Credentials
Enter your credentials, then click Save. The WiFi Credentials will be saved and the board reboots to connect to the selected WiFi AP.
If you’re already connected to a listed WiFi AP and don’t want to change anything, just select Exit Portal from the Main page to reboot the board and connect to the previously-stored AP. The WiFi Credentials are still intact.
Debug Termimal Output Samples
  1. This is terminal debug output when running Async_ConfigOnDoubleReset on ESP32 ESP32_DEV.. Config Portal was requested by DRD to input and save Credentials. The boards then connected to WiFi using new Static IP successfully. WiFi AP HueNet1 is then lost, and board autoreconnects itself to backup WiFi AP HueNet2.
Starting Async_ConfigOnDoubleReset with DoubleResetDetect using SPIFFS on ESP32_DEV
[WM] RFC925 Hostname = ConfigOnDoubleReset
[WM] setSTAStaticIPConfig for USE_CONFIGURABLE_DNS
[WM] Set CORS Header to :  Your Access-Control-Allow-Origin
Stored: SSID = HueNet1, Pass = 12345678
[WM] * Add SSID =  HueNet1 , PW =  12345678
Got stored Credentials. Timeout 120s for Config Portal
SPIFFS Flag read = 0xd0d01234
doubleResetDetected
Saving config file...
Saving config file OK
Open Config Portal without Timeout: Double Reset Detected
Starting configuration portal.
[WM] WiFi.waitForConnectResult Done
[WM] SET AP
[WM]
Configuring AP SSID = ESP_E92DE6B4
[WM] AP PWD = your_password
[WM] AP Channel = 3
[WM] AP IP address = 192.168.4.1
[WM] HTTP server started
[WM] ESPAsync_WiFiManager::startConfigPortal : Enter loop
[WM] Connecting to new AP
[WM] Previous settings invalidated
[WM] Custom STA IP/GW/Subnet
[WM] DNS1 and DNS2 set
[WM] setWifiStaticIP IP = 192.168.2.232
[WM] Connect to new WiFi using new IP parameters
[WM] Connected after waiting (s) : 0.60
[WM] Local ip = 192.168.2.232
[WM] Connection result:  WL_CONNECTED
WiFi connected...yeey :)
[WM] * Add SSID =  HueNet2 , PW =  12345678
[WM] SaveWiFiCfgFile
[WM] OK
After waiting 0.00 secs more in setup(), connection result is connected. Local IP: 192.168.2.232
[WM] freeing allocated params!
HH
WiFi lost. Call connectMultiWiFi in loop
[WM] ConnectMultiWiFi with :
[WM] * Flash-stored Router_SSID =  HueNet1 , Router_Pass =  12345678
[WM] * Additional SSID =  HueNet1 , PW =  12345678
[WM] * Additional SSID =  HueNet2 , PW =  12345678
[WM] Connecting MultiWifi...
[WM] WiFi connected after time:  2
[WM] SSID: HueNet2 ,RSSI= -51
[WM] Channel: 4 ,IP address: 192.168.2.232
HHHHHHHHHH HHHHHHHHHH HHHHHHHHHH HHHHHHHHHH
  1. This is terminal debug output when running Async_ConfigOnDoubleReset on ESP8266_NODEMCU.. Config Portal was requested by DRD to input and save Credentials. The boards then connected to WiFi using new Static IP successfully. WiFi AP HueNet1 is then lost, and board autoreconnects itself to backup WiFi AP HueNet2.
Starting Async_ConfigOnDoubleReset with DoubleResetDetect using LittleFS on ESP8266_NODEMCU
LittleFS Flag read = 0xd0d01234
doubleResetDetected
[WM] SET AP_STA
[WM]
Configuring AP SSID = ESP_119055
[WM] AP Channel = 5
[WM] setWifiStaticIP IP = 192.168.2.186
[WM] Connected after waiting (s) : 3.23
[WM] Local ip = 192.168.2.186
[WM] OK
After waiting 0.00 secs more in setup(), connection result is connected. Local IP: 192.168.2.186
HHH
[WM] WiFi connected after time:  1
[WM] SSID: HueNet2 ,RSSI= -50
[WM] Channel: 4 ,IP address: 192.168.2.186
Demonstrating pictures when running Async_ESP32_FSWebServer_DRD
  1. Edit / Delete / Download any file in the the folder by going to http://async-esp32fs.local/edit
