ESP8266ex do not run a flashed schecth
I am working with ESP8266 and flash a very simple program, and do not run, but if flash the same program or even one more complicate in another ESP8266 run fine the only diference between the to ESP is the manufactures code
Not Work Manufacturer: e5 (Tested in 5 diferent ESP)
Work Manufacturer: 85 20 (Work fine in other all 16 ESP)
is a malfunction? or need use parameter to flash
How is this related to Blynk?
