It’s the new version of Blynk…
So I use that alredy long time. And what we tolking about?
Well, you talked about local server, which is Legacy not IoT, and Bridge, which is also Legacy and not IoT.
Posting code snippets, and not providing the information about which version of Blynk you are using - which is requested when you create a topic, means we have to make assumptions, and everything you’ve posted leads to the assumption that you are using Legacy not IoT.
If you want to transfer data from a salve device to a master in IoT the. You can use Automations in some situations.
If Automations don’t provide the functionality you’re looking for then the HTTP(S) API can be used to simulate the Bridge functionality of Legacy…
and…
Ok. That is good. Now maybe U can call some one, who can expain me somesing?
I don’t understand.
Что мне делать с этим?
Как заставить обмениваться данными между двумя ESP8266, одна из которых подключена к Blynk?
Both of the ESPs will communicate via the Blynk server.
They don’t talk to each other directly.
That’s a good thing. Thank you so much for answering me. Can you show me a simple example? Which libraries need to be downloaded/updated? What should be declared and initialized in both controllers? I, at this point, have no idea where to start.
P.S. Looks like I get it. Is it equivalent to a GET request from the web browser’s address bar?
It’s all in the links I provided.
Correct.
Could You just give me link with exammles?
I understand what you’re talking about. That’s what I need. But I can’t do anything practical… I don’t know what to write.
https://github.com there are no examples on the topic of blynk-server.
I’d suggest that you post your code and the actual full compiler error message, not just as partial screenshot.
You also need to clarify whether you’re trying to compile this for an ESP8266 or ESP32.
void api_bridge(String token, int virtual_pin, float value_to_send) {
HTTPClient http;
String server_path = server_name + “update?token=” + token + “&pin=v” + String(virtual_pin) + “&value=” + float(value_to_send)
if(...) { api_bridge(auth, V16, valv); }
Both ESP8266.
Arduino: 1.8.9 (Windows 7), Плата:“NodeMCU 1.0 (ESP-12E Module), 80 MHz, Flash, Disabled (new aborts on oom), Disabled, All SSL ciphers (most compatible), 32KB cache + 32KB IRAM (balanced), Use pgm_read macros for IRAM/PROGMEM, 4MB (FS:2MB OTA:~1019KB), 2, v2 Lower Memory, Disabled, None, Only Sketch, 115200”
Boiler:195:38: error: extended character “ is not valid in an identifier
195 | String server_path = server_name + “update?token=” + token + “&pin=v” + String(virtual_pin) + “&value=” + float(value_to_send)
Boiler:195:54: error: extended character ” is not valid in an identifier
Boiler:195:68: error: extended character “ is not valid in an identifier
Boiler:195:76: error: extended character ” is not valid in an identifier
Boiler:195:105: error: extended character “ is not valid in an identifier
Boiler:195:115: error: extended character ” is not valid in an identifier
exit status 1
Этот отчёт будет иметь больше информации с
включенной опцией Файл → Настройки →
“Показать подробный вывод во время компиляции”
Okay, that appears to be caused by using the wrong quotation mark symbols.
This … "
is the correct symbol. The compiler doesn’t recognise “ or ” as being valid quotation mark symbols.
Yes you are right. I don’t know how I didn’t notice it.
Which library do I need to include?
Boiler:194:3: error: ‘HTTPClient’ was not declared in this scope
194 | HTTPClient http;
Boiler:195:24: error: ‘server_name’ was not declared in this scope; did you mean ‘server_path’?
195 | String server_path = server_name + “update?token=” + token + “&pin=v” + String(virtual_pin) + “&value=” + float(value_to_send);
| server_path
exit status 1
It’s all in the link I provided…
what link are You always talking about?
| server_path
exit status 1
The two links in post #8 - the original one for the ESP32 and the second one which modifies that code to work for the ESP8266 in an Edgent sketch.
You’ve clearly followed at least one of them as you’ve copied pieces of my code from there - and created some issues for yourself in the process by not copying all of the relevant pieces.
This error is caused because you didn’t bother to copy the line that begins String server_name =
Copy
// Your Domain name with URL path or IP address with path
http.begin(my_wifi_client, server_path.c_str());
Это должно быть внутри функции api_bridge, или в другом месте.
Я не программист, я не знаю как правильно работать с интернетом.
You appear to be referring to the code snippets from the top of this post…
These snippets of code outline a modification made to the full sketch that follows, because of a change in the way that the ESP8266 core works from version 3.0.x onwards.
Below these snippets of code, after the words “[END OF 14th January 2022 EDIT]]”, there is a full working Edgent .ino sketch.
If you aren’t able to take this working sketch and modify it to suit your purposes then I can’t really help you any further.
