ESP8266 Witty Cloud with relay, always stays On
• Hardware model + communication type. ESP8266 Witty Wifi Cloud, Low level Trigger 1CH relay board
• Smartphone OS (iOS or Android) + version: Android 8.0
• Blynk server or local server: Blynk server
• Blynk Library version : Latest
• Add your sketch code.
const char auth[] = "Auth-code";
const char ssid[] = "xxxxxx";
const char pass[] = "yyyyy";
int relay = 5;
BLYNK_WRITE(V5)
  pinMode(relay, OUTPUT);
  if (digitalRead(relay) == LOW)
    digitalWrite(relay, HIGH);
    Serial.print("Pin set to HIGH");
    digitalWrite(relay, LOW);
    Serial.print("Pin set to LOW");
  pinMode(relay, INPUT);
  pinMode(led, OUTPUT);
  // Initiates Blynk Connection
  if (Blynk.connected())
After uploading the sketch, disconnected the ESP8266 module from the bottom board. Connected the relay IN pin to the GPIO05 on the board, and the VCC/GND of relay, are connected to external power of 5V. Below are the screenshots of Blynk App project.
The issue I’m facing is that the relay just stays on, after I press the run on app. Basically the voltage on the GPIO05 pin remains at 3.3 V, which seems to be insufficient for the relay to register a HIGH to switch off. But surprisingly, when I just connect the board and relay to power, initially, the relay is Off, which means it’s getting 5v somehow to register a HIGH. But this becomes a LOW when I execute from Blynk App and then the button press on the app does no affect at all. the Relay just stays On.
Any ideas on what am I missing here? Is there anything missing in the code, or the hardware setup?
Start with removing the pinMode in the BLYNK_WRITE. This is usually done in setup(), but it has no function whatsoever, worse, I think it’s your problem :wink:
Thanks for the tip, but unfortunately, It’s still not working. Now, the relay stays Off, though. Never turns On, when operating the button from the app.
I made the following changes to the code:
const char auth[] = "AuthCode";
const char ssid[] = "xxxxxxx";
const char pass[] = "yyyyyy";
int led = 13;
int relay = 5;
BLYNK_WRITE(V1)
Also changed the app settings accordingly:
Anything else I should change?
Made some more changes to the setup(), and now the relay again went back to staying On…
Still can’t turn off from the app…
If GPIO5 the right pin to connect the IN pin of the relay, according to the code?
(PS: I’m using NodeMCU1.0 as the board in Arduino IDE.)
I see it :slight_smile:
BLYNK_WRITE(V1)
  int status = param.asInt();
  digitalWrite(relay) == status;
I looked over the fact you have to catch the parameter from the button. And that is done like in this code.
Sorry, I’m not sure I followed you here. The second line looks like a condition with ==.
Was it a typo?
Assuming that was a typo, I wrote the method like this:
BLYNK_WRITE(V1)
  digitalWrite(relay, status);
But still no improvement :frowning:. The relay still remains On, and can’t switch Off from the app.
No, = means assigning a value to a parameter. == is a conditional statement.
