ESP8266 was't online yet
Getting msg in blynk - was’t online yet??
Any help
Why not help us by providing the information that was requested whne you created this topid…
Before creating the topic
  1. Search forum for similar topics
  2. Check http://docs.blynk.cc and http://help.blynk.cc/
  3. Add details :
    • Blynk Library version
    • Add your sketch code. :point_up:Code should be formatted as example below.
```cpp
@PeteKnight Thanks for quick reply- is anything wrong with the below code -
You code has been removed, because you didn’t follow the rules about formatting it correctly.
and PLEASE PROVIDE ALL OF THE INFORMATION REQUESTED!
I share my kit as well… @PeteKnight
@PeteKnight pls check the above code…
You need to copy and paste the triple backticks provided earlier if you can’t find the correct characters on your keyboard.
I won’t be checking anything until you provide ALL of the requested information.
