ESP8266 Standalone error
I use a NodeMCU esp8266 and I tried to use the ESP8266 Standalone sketch but I always get the following error:
wdt
reset
load
0x4010f000, len 1384, room 16
tail
8
chksum
0x2d
csum
0x2d
v3de0c112
~ld
Do you have any idea what the problem could be?
I have downloaded the Blynk library (following the “Getting Started” tutorial: http://docs.blynk.cc/#getting-started-blynking )
Thanks for your answer
What memory settings have you allocated in the IDE?
I’m not sure but I didn’t change anything about the meymory settings… Do you know where I could find these settings?
try these settings and work backwards starting with flash size.
Thanks for your answer. I have the same settings as you, except for the board (I use a NodeMCU esp8266-12E and not an Adafruit esp8266), so I always get the same error…
https://github.com/blynkkk/blynk-library/wiki/ESP8266-standalone
Thanks for the link, I have just downloaded the last version of the libraries and it works fine :slight_smile:
