I was using this rellay with the previous version of blynk, (as a simple button) but with the new one i cant fix it . Does anyone have the code ?or some guide?
Thank you.
Thank you.
Which relay?
What board are you using to drive the relay?
Posting your Legacy sketch (correctly formatted with triple backticks) would be a good starting point.
First of all thank you for your reply, so i can see my device online but i cant get it to work.
The skeech im using is this
#define BLYNK_TEMPLATE_ID "TMPLAvmeTYmV"
#define BLYNK_DEVICE_NAME "Quickstart Template"
#define BLYNK_AUTH_TOKEN "****"
char ssid[] = "**";
char pass[] = "***";
//Blynk.begin(auth, ssid, pass, "blynk.cloud", 80);
// to avoid delay() function!
@Bandicoot929 Please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code so that it displays correctly.
Sorry, didnt know that. I just did it.
i didnt know what triple backticks was
I guess you’re using a digital pin datastream. If so, I’d suggest using virtual pins instead.
https://docs.blynk.io/en/blynk.edgent-firmware-api/virtual-pins
And you didn’t post your working legacy sketch. We’re still waiting.
Pete:
Despite my diligent attempts at migration of my/our well-conditioned Arduino code and the NEW “features” of Blynk Iot, I have given up. Finding that developing the appropriate “templates” caused the device to “crash” and become un-recoverable by reverting the template configurations I DELETED them to begin again where they worked for an input or two. Now I find that I have used all of my FREE privileges trying to get legacy Arduino sketches to function.
With greatest respect for your extraordinary support capability and efforts, I’m DONE with BLYNK !!!
Recommend all similarly frustrated users to switch to TASMOTA with all IoT and user features to suit most of us non-software professionals. In only a few hours I had all my devices reconfigured and operating with Alexa without a four-week study of Arduino code to accommodate for the foolishness of BLYNK.
Most sincere regards.
LA
