esp8266 shied
Arduino: 1.0.6 (Mac OS X), Board: “Arduino Uno”
/Users/macbookpro/Downloads/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -Wall -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -MMD -DUSB_VID=null -DUSB_PID=null -DARDUINO=106 -I/Users/macbookpro/Downloads/Arduino.app/Contents/Resources/Java/hardware/arduino/cores/arduino -I/Users/macbookpro/Downloads/Arduino.app/Contents/Resources/Java/hardware/arduino/variants/standard -I/Users/macbookpro/Documents/Arduino/libraries/ITEADLIB_Arduino_WeeESP8266-master /var/folders/fh/k6ywrcjj2lbcfthfbt7nb96m0000gn/T/build4407718192299724650.tmp/ESP8266_Shield.cpp -o /var/folders/fh/k6ywrcjj2lbcfthfbt7nb96m0000gn/T/build4407718192299724650.tmp/ESP8266_Shield.cpp.o
In file included from ESP8266_Shield.ino:40:
/Users/macbookpro/Documents/Arduino/libraries/ITEADLIB_Arduino_WeeESP8266-master/BlynkSimpleShieldEsp8266.h:15:29: warning: BlynkApiArduino.h: No such file or directory
/Users/macbookpro/Documents/Arduino/libraries/ITEADLIB_Arduino_WeeESP8266-master/BlynkSimpleShieldEsp8266.h:16:33: warning: Blynk/BlynkProtocol.h: No such file or directory
/Users/macbookpro/Documents/Arduino/libraries/ITEADLIB_Arduino_WeeESP8266-master/BlynkSimpleShieldEsp8266.h:17:31: warning: utility/BlynkFifo.h: No such file or directory
/Users/macbookpro/Documents/Arduino/libraries/ITEADLIB_Arduino_WeeESP8266-master/BlynkSimpleShieldEsp8266.h:149:26: warning: BlynkWidgets.h: No such file or directory
BlynkSimpleShieldEsp8266.h:90: error: ISO C++ forbids declaration of ‘BlynkFifo’ with no type
BlynkSimpleShieldEsp8266.h:90: error: expected ‘;’ before ‘<’ token
/Users/macbookpro/Documents/Arduino/libraries/ITEADLIB_Arduino_WeeESP8266-master/BlynkSimpleShieldEsp8266.h: In member function ‘void BlynkTransportShieldEsp8266::onData(uint8_t, uint32_t)’:
BlynkSimpleShieldEsp8266.h:30: error: ‘buffer’ was not declared in this scope
BlynkSimpleShieldEsp8266.h:31: error: ‘BLYNK_LOG’ was not declared in this scope
/Users/macbookpro/Documents/Arduino/libraries/ITEADLIB_Arduino_WeeESP8266-master/BlynkSimpleShieldEsp8266.h: In member function ‘void BlynkTransportShieldEsp8266::disconnect()’:
BlynkSimpleShieldEsp8266.h:62: error: ‘buffer’ was not declared in this scope
/Users/macbookpro/Documents/Arduino/libraries/ITEADLIB_Arduino_WeeESP8266-master/BlynkSimpleShieldEsp8266.h: In member function ‘size_t BlynkTransportShieldEsp8266::read(void*, size_t)’:
BlynkSimpleShieldEsp8266.h:68: error: ‘buffer’ was not declared in this scope
BlynkSimpleShieldEsp8266.h:71: error: ‘buffer’ was not declared in this scope
/Users/macbookpro/Documents/Arduino/libraries/ITEADLIB_Arduino_WeeESP8266-master/BlynkSimpleShieldEsp8266.h: In member function ‘int BlynkTransportShieldEsp8266::available()’:
BlynkSimpleShieldEsp8266.h:84: error: ‘buffer’ was not declared in this scope
/Users/macbookpro/Documents/Arduino/libraries/ITEADLIB_Arduino_WeeESP8266-master/BlynkSimpleShieldEsp8266.h: At global scope:
BlynkSimpleShieldEsp8266.h:96: error: expected template-name before ‘<’ token
BlynkSimpleShieldEsp8266.h:96: error: expected `{’ before ‘<’ token
BlynkSimpleShieldEsp8266.h:96: error: expected unqualified-id before ‘<’ token
Please be more descriptive, otherwise your post will be deleted.
Thanks for understanding.
Your arduino ide or library installation is broken. Reinstall everything…
