Would a delay in the code work to reset my servo controlled light switch back to a neutral position? Right now I have a Switch/Button in the Blynk app set to various values to switch the light switch at home to on or off. I want to have it reset to a neutral position after the button is switched to on or off.
#include <Servo.h>
char pass[] = "YourPassword";
Servo servo;
BLYNK_WRITE(V3) {
servo.write(param.asInt());
#these two lines are my edits delay(500);
#servo.write(60);
// Debug console Serial.begin(115200);
servo.attach(15); // 15 means D8 pin of ESP8266
Blynk.run(); // You can inject your own code or combine it with other sketches.
