Esp8266 not responding (esp8266 12-f)
So ive been trying to connect my esp8266mod (esp8266 12-f) to my arduino uno. Ive downloaded blynk 0.6.1 library but when i connect the esp to arduino uno and run the sketch below, i get an error on serial monitor saying “[1608] ESP Not Responding”. I ve tried changing the baud rate to 9600 but then i get an error sayin “[1612] ESP Not Responding”. What might be the problem in this case ? My connections to arduino and esp are below.
Arduino <---------> Esp
Gnd ----------- Gnd
pin2 ----------- RX
pin3 ----------- TX
I also tried using an external power supply for the esp but no help.
#include <ESP8266_Lib.h>
char auth[] = "myauthtoken";
char ssid[] = "Inca";
char pass[] = "wifipassword";
//#define EspSerial Serial1
// Your ESP8266 baud rate:
#define ESP8266_BAUD 11520
ESP8266 wifi(&EspSerial);
  // Set ESP8266 baud rate
  //Blynk.begin(auth, wifi, ssid, pass, "blynk-cloud.com", 80);
  //Blynk.begin(auth, wifi, ssid, pass, IPAddress(192,168,1,100), 8080);
  // to avoid delay() function!
RX needs to go to TX and visa versa
I ve tried but the result is same :frowning:
Well, search this forum for keywords like ESP-01, ESP as shield, your error message, etc… This issue and all solutions (like proper SoftwareSerial connection and BAUD rate for shields) have have been repeatedly discussed more times than needed.
I’ll be looking. Thanks!
A crazy question but it is a least … if you connect the esp-12f Vcc with 3.3VDC? :slight_smile:
…and not only that but also: pull down for pin 15, pull up for pins rst, … ask Google haha
