ESP8266 not connecting to router
I’m trying to connect to wifi router using ESP8266 and Arduino UNO. I get this
[9] Connecting to wifi
It stays like that and does not connect
My code:
//#define BLYNK_DEBUG
#include <ESP8266.h>
// Set ESP8266 Serial object
//#define EspSerial Serial
// This can be a SoftwareSerial object (remember to also edit ESP8266.h):
#include "SoftwareSerial.h"
ESP8266 wifi(EspSerial);
char auth[] = "123";
  Serial.begin(9600);     // Set console baud rate
  EspSerial.begin(9600);  // Set ESP8266 baud rate
  Blynk.begin(auth, wifi, "wifi", "12345678");
This is not going to work because you need to attach it to the serial port and the UNO has only one. So you can use that one serial port for either the ESP as a shield or serial output or use software serial as stated in the comments of the sketch.
It may also be advisable to upgrade your Blynk library to 0.3.1. because it works better with software serial I believe.
