ESP8266 module and teensy 3.6 uart port
in my project i want to use the module esp8266 and i want to ask that.
Ι use the teensy 3.6 which has 6 serial ports,i have only 5th and 6th serial port available.If i connect the esp8266 in serial port 5th It will work for me οr it must necessarily be connected in serial port 1 on teensy?
Thanks.
Should be fine and if it’s not you can use SoftwareSerial with any pins.
Thank you so much for the reply,i do not have it yet module and so i can not test it.
I wish it to work in the uart5 because i have make it the pcb and so i can not make changes,you have tried if it works on another uart port apart from uart1?
Thanks.
No, I don’t have any teensy 3.6’s.
Hello again,the esp-12f is supported?
Yes but if you haven’t already bought / ordered the 12F you might want to consider a plug and play ESP.
When you factor in power supplies and USB 2 TTL adaptors the plug and play ESP’s are not really any more expensive than the bare ESP’s. Certainly easier to work with an ESP that has a USB port than one that doesn’t.
Ok thanks.
