ESP8266 keeps getting disconnected if Iphone app is open
Hello there,
No sure if this has been posted before, but as soon as I open my Iphone app, my ESP8266 serial port keeps getting disconnected. If the iphone app is closed, everything looks smooth and nice.
I am using the ESP8226 HUZZAH by AdaFruit.
Iphone 7+, iOS 10
Here is the code I am using. I attached a screenshot, too.
#include "SHT31.h"
SHT31 sht31;
char auth[] = "xxxxxxxxxxxxxxxxxxxxxx";
  Blynk.begin(auth, "xxxxxxxx", "vvvvvvvvv");
  timer.setInterval(3000L, virtualPins);
  timer.setInterval(3000L, loop2);
  sht31.heater(true);
  sht31.reset();
  Wire.begin(4, 5); // Define I2C SDA & SCL pins.
  Serial.println("Humidity\t\  Temp \t\    DewPoint");
void loop2()
float g;
Serial.print(sht31.getHumidity()); Serial.print(" %\t\t");
Serial.print(sht31.getTemperature_F()); Serial.print(" *F\t");
g = sht31.getDewPoint() * 1.8 + 32;  // Convert C DewPoint to F DewPoint
Serial.print(g); Serial.println(" *F\t");
void virtualPins()
  sht31.begin();
  float DewP_F;  // Convert C DewPoint to F DewPoint
  DewP_F = sht31.getDewPoint() * 1.8 + 32;
  Blynk.virtualWrite(10, sht31.getTemperature_F());
   Blynk.virtualWrite(11, sht31.getHumidity());
   Blynk.virtualWrite(12, DewP_F);
   Blynk.virtualWrite(13, sht31.getTemperature_F());
   Blynk.virtualWrite(14, sht31.getHumidity());
Hello. Do you have reading widgets?
Yes, I do. I am using Value Display and History Graph connected to virtual pins 10 - 14.
I mean widget that have 'Frequency Reading" setting that is not in “PUSH” mode.
Dmitriy:
No sure if I understand your question. Here is more or less what I have done to stop getting disconnected, time out, log out, etc. It seems to me that if I add more than 5 Blynk.virtualWrite, I get that issue, 5 or less seem to work fine.
I mean such widgets - http://docs.blynk.cc/#blynk-main-operations-get-data-from-hardware-perform-requests-by-widget
Oh OK, Dmitriy, got it. I am using Frequency Reading rather than Push. Will this make a difference? As I said before,if I use more than 5 virtual pins, the serial port shows disconnected, log out, etc.
Yes. YOu need to check with PUSH mode only. This should fix issue.
Dmitriy:
Yes Sir, this fixed the issues, problem solved. You are the man.
Thank you for your time.
