ESP8266 is offline
Before creating the topic
  1. Search forum for similar topics
  2. Check http://docs.blynk.cc and http://help.blynk.cc/
  3. Add details :
    • Blynk Library version
    • Add your sketch code. :point_up:Code should be formatted as example below.
Hi
I have a WEMOS mini that works well at home using a COMCAST router with their standard encryption (I assume WPA/WPA2).
I moved the board to another location using a NETGEAR router on ATT and it remains offline. I know the SSID and password were correctly changed in the code. The encryption at the new location is WPA2-PSK(AES). When I turned the encryption off (network now open), the board went on line and worked as expected. Other options available are:WEP and WPA-PSK(TKIP).
How can I get the board to work at the new location while still have network security?
