What do you mean by “same” IOS projects? They cannot be same if you use different servers. Also I didn’t get your email
I will resend my account id. What I meant by “same IOS projects” is that I am using identical dashboard and Arduino code for both - not literally the same but coded using the same widgets and Arduino HW. Different auth tokens, accounts and projects of course.
Drew
Ah. Ok. I don’t see any related errors. What token do you use?
Dmitriy, here is the latest:
Auth Token for project “bf9845a237214a7e81b2fe6e097ff84f”
Drew
Nothing in logs. Are you sure you are connecting to Blynk Cloud? Please double check.
Dmitriy, well, it seems to be working now! Here is what I got in the monitor window just now (token was 4f314acc1a9243799af1ed968dd76ab1)
[0] Blynk v0.3.3
[0] Getting IP…
[5643] My IP: 10.0.0.5
[5644] Connecting to cloud.blynk.cc:8442
[10098] Ready (ping: 85ms).
Not sure why it wasn’t going earlier…I might have gotten projects/apps/code and cloud/local mixed up. It is a bit confusing now to manage versions across several apps and HW devices!, both cloud and local. Thanks again for your help!
Drew
Yeah, It is a bit hard at the moment. Soon we will improve that
. Glad everything works now.
