ESP8266 + HR SC04 Issue
Hi.
I have successfully run ESP8266 Feather Huzzah + HR SC04 by pining it in the loop functin. Getting correct vales for the ultra sonic distance
However when i move the code to blynk sketch. Occationaly the sketch will not even connect to Blynk or it connects and returns just zero. Am i missing something?
#include <NewPing.h>
#define TRIGGER_PIN  2
#define ECHO_PIN     0
#define MAX_DISTANCE 200
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE);
char auth[] = "my authen code here";
WidgetLCD lcd(V0);
  Blynk.begin(auth, "my wifi name", "my wifi pass");
  delay(100);
  timer.setInterval(1000, ultra);
void ultra()
  unsigned int uS = sonar.ping_cm();
  Serial.println(uS);
  lcd.clear(); //Use it to clear the LCD Widget
  lcd.print(0,0,"Distance (cm):");
  lcd.print(0,1,(uS));
Seems fine. Could you please post the code that works without Blynk?
@Blynk182 notice you are using pin 0 and 2. Not the best pins to use, try others.
// Example NewPing library sketch that does a ping every second.
#define TRIGGER_PIN  2  // Arduino pin tied to trigger pin on the ultrasonic sensor.
#define ECHO_PIN     0  // Arduino pin tied to echo pin on the ultrasonic sensor.
#define MAX_DISTANCE 200 // Maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 400-500cm.
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
  Serial.begin(115200); // Open serial monitor at 115200 baud to see ping results.
  delay(1000);                     // pings every second
  Serial.print("Ping: ");
  Serial.print(sonar.ping_cm()); // Send ping, get distance in cm and print result (0 = outside set distance range)
  Serial.println("cm");
I was able to fix the intermitten connection issue by always hard reseting the device by disconnecting the power and then connecting it.
But there is def some issue getting sonar.ping_cm() to work on any part of the sketch.
I was able to run a simple counter variable and get that to display on the lcd blynk module file.
Thanks for your help Dimitriy
Hey That did the trick.
Thanks for the tip.
Solved :slight_smile:
