ESP8266 Heating Controller with Blynk UI
Just thought i’d show off my ESP8266 Heating Controller/Thermostat with Blynk interface project.
HEATING PROJECT
Great project. Can you please help me what shuld I change in code if I have simple relay board controling my heater instead of 433mhz radio module.
I guess that only
void heatingControl(boolean onOff)
 Serial.print(millis());
 Serial.println(" Transmitting " + String(onOff ? "ON signal" : "OFF signal"));
 int on[]   = {0, 0, 0, 0, 0, 0, 0, 1, 0, 2, 0, 0, 1, 1, 0, 1, 0, 0, 0, 1, 0, 0, 0, 0, 0, 1, 0, 0, 0, 0, 0, 1, 0, 1, 0, 0, 1};
 int off[]  = {0, 0, 0, 0, 0, 0, 0, 1, 0, 2, 0, 0, 1, 1, 0, 1, 0, 0, 0, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 0, 0, 1, 0, 0, 1};
 for (int repeat = 1; repeat <= 3; repeat++)
   for (int i = 0; i < sizeof( onOff ? on : off  ) / sizeof( int ); i++) {
 switch (onOff ? on[i] : off[i])
   case 0:
     digitalWrite(dataPin, LOW);
     delayMicroseconds(500);
     digitalWrite(dataPin, HIGH);
     break;
   case 1:
     break;
   case 2:
     break;
   int waitTime = millis();
   if ((millis() - waitTime) < 1000) {
 Blynk.virtualWrite(V1, String(onOff ? "Heating ON" : "Heating OFF"));
 Blynk.setProperty(V1, "color", String(onOff ? "#00FF00" : "#FF0000"));
 lastTransmit = millis();
should be changed with something like
BLYNK_WRITE(V1)
int buttonState = param.asInt();
if (param.asInt()==1)
digitalWrite(14, HIGH);
digitalWrite(14, LOW);
Yes, that is correct.
