esp8266-hardware and esp8266-software code not compiling
  • Blynk is a platform with iOS and Android apps to control
  • Arduino, Raspberry Pi and the likes over the Internet.
  • You can easily build graphic interfaces for all your
  • projects by simply dragging and dropping widgets.
  • Downloads, docs, tutorials: http://www.blynk.cc
  • Blynk community: http://community.blynk.cc
  • Social networks: http://www.fb.com/blynkapp
  •                           http://twitter.com/blynk_app
  • Blynk library is licensed under MIT license
  • This example code is in public domain.
  • This example shows how to use ESP8266 Shield via Software Serial
  • (on Uno, Nano…) to connect your project to Blynk.
  • Note: Ensure a stable serial connection to ESP8266!
  •   Firmware version 1.0.0 (AT v0.22) or later is needed.
  •   Set ESP baud rate to 9600. Connect to AT console and call:
  •       AT+UART_DEF=9600,8,1,0,0
  •   In general, Soft Serial is unstable.
  •   It is highly recommended to switch to Hard Serial.
  • Change WiFi ssid, pass, and Blynk auth token to run :slight_smile:
  • Feel free to apply it to any other example. It’s simple!
//#define BLYNK_DEBUG
#include <ESP8266_SoftSer.h>
#include <BlynkSimpleShieldEsp8266_SoftSer.h>
// Set ESP8266 Serial object
ESP8266 wifi(EspSerial);
char auth[] = “902405f7086c4bf3a683d2bab0e09e39”;
// Set console baud rate
// Set ESP8266 baud rate
// 9600 is recommended for Software Serial
EspSerial.begin(9600);
Blynk.begin(auth, wifi, “scientist”, “9820494181”);
error
ESP8266_Shield_SoftSer.ino:33:29: fatal error: ESP8266_SoftSer.h: No such file or directory
compilation terminated.
Multiple libraries were found for “BlynkSimpleShieldEsp8266_SoftSer.h”
Used: C:\Users\soumil\Documents\Arduino\libraries\blynk-library-master
Not used: C:\Program Files (x86)\arduino-1.6.4\libraries\blynk-library-0.3.1
Not used: C:\Users\soumil\Documents\Arduino\libraries\blynk-library-0.3.1
Error compiling.
Error compiling.
@scientist1995 as you have a Mega you don’t want soft serial use hard serial.
When pasting sketches highlight the text and then press the </> icon.
Just go through Getting Started guide: http://www.blynk.cc/getting-started/
i also mett this question,but i get a ESP8266_HardSer.h document and ESP8266_HardSer.app
i got a BlynkESP8266_SoftSer.h and BlynkESP8266_SoftSer.cpp,if you want to get replay me
