ESP8266_hardser support gone?
Hi, Just downloaded 0.3.10 and found ESP8266_HardSer and ESP8266_SoftSer directory missing. Is that support gone? What is the latest release that support this method of communication and what is the compatible server version with that release?
Or did you just forget to add these directories to the build?
Which IDE are you using as Arduino IDE will almost certainly give you the required examples in the Blynk folder?
@mrohner support is there. However library structure was changed. Please remove old library and install new one. And follow latest examples. Latest server is 0.18.3
