... Esp8266_HardSer.h: No such file or directory
I had to reinstall my Mac Book Pro (El Capitan version) and some Sketches with Blynk involved don´t compile now. My original libraries definition is:
Arduino.h
Wire.h
Time.h
DS1307RTC.h
SD.h
SPI.h
ESP8266_HardSer.h
BlynkSimpleShieldEsp8266_HardSer.h
SimpleTimer.h
With the following build result:
"… fatal error: BlynkSimpleShieldEsp8266_HardSer.h: No such file or directory "
In the Blynk github repository I could´t find these versions for ESP8266 acting as shield.
And when a tried to integrate the new versions:
ESP8266_Lib.h
BlynkSimpleShieldEsp8266.h
I obtain this new error:
“… .pioenvs/megaatmega2560/Blynk/linux/main.cpp:15:28: fatal error: BlynkApiLinux.h: No such file or directory”
I use PlatformIO IDE and Arduino Mega 2560.
Please, I’ll appreciate any help.
Regards and thanks in advance.
How did you install the Blynk libraries? You need to unzip them manually to your sketchbook, te auto-installer does something wrong.
-edit-
Make sure you use IDE 1.6.9 and not the latest, as always there are bugs …
Thanks for your indications.
I am using PlatformIO 1.4.0. The first Blink Library installation was made through Library Manager, and after I red your comments in the community I followed your instructions (copy the four libraries en the lib directory) but the result is:
“… fatal error: BlynkApiLinux.h: No such file or directory”
Please, at any case,
Could you provide a copy of the old Library (BlynkSimpleShieldEsp8266_HardSer)?
Thanks again.
There are no longer HardSer/SoftSer libraries. There is one merged.
Just download the latest Blynk libraries release zip package
