Esp8266 failed to restart
Hi communtiy !
I’m runing esp8266 with this sketch :
char auth[] = "xxxx";
char ssid[] = "xxx";
char pass[] = "xxx";
  //Blynk.begin(auth, ssid, pass);
  Blynk.begin(auth, ssid, pass, IPAddress(192,168,xx,xx), 8080);
  // to avoid delay() function!
All work fine exepect for restart. If i restart it don’t run sketch ( no wifi connexion, no blue LED )
I have to unpleged output 5V ( relay alimentation ) for good restarting
Some idea about this issues ?
At least on the ESP01 the CHP_EN, GPIO 0 and 2 must be high (pullups). RST must also be high unless your resetting then it goes low and high.
