Check the link I sent you for more details.
Yes, I added a switch widget and used virtual datastream if I remember correctly.
I deleted the switch in attempt to troubleshoot and I am now trying to just use the blank Blynk provided template āESP8266_Standaloneā and if I use:
I get an invalid authentication code error which is why I switched it to:
Blynk.begin(auth, ssid, pass, "blynk.cloud", 80);
because that was what was working before. However, now the code is not getting past the Blynk.begin() function because if I put a serial print statement before and after the code, it prints the first but not the second. See below.
Also thanks for the help!
My Sketch:
http://twitter.com/blynk_app
This example runs directly on ESP8266 chip.
Please be sure to select the right ESP8266 module
in the Tools -> Board menu!
/* Fill-in your Template ID (only if using Blynk.Cloud) */
//#define BLYNK_TEMPLATE_ID "TMPLQyxtVycX"
char auth[] = "C3xwkgth6nijpJhQPBWvfcJObEuRk1J1";
char ssid[] = "Galaxy S21";
char pass[] = "KyleSanchez";
Serial.println("BEFORE begin func");
Serial.println("AFTER begin func");
Serial Output:
BEFORE begin func
[292] Connecting to Galaxy S21
[5522] Connected to WiFi
[5522] IP: 192.168.135.32
[5522]
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ \/ '_/
/____/_/\_, /_//_/_/\_\
/___/ v1.1.0 on ESP8266
#StandWithUkraine https://bit.ly/swua
[5533] Connecting to blynk.cloud:80
[5725] Ready (ping: 101ms).
ets Jan 8 2013,rst cause:4, boot mode:(3,6)
wdt reset
load 0x4010f000, len 3460, room 16
tail 4
chksum 0xcc
load 0x3fff20b8, len 40, room 4
tail 4
chksum 0xc9
csum 0xc9
v000461c0
~ld
Look at the datastreams that you have in the template you are using and provide the actual details.
The Blynk 1.x.x library will automatically compile the code so that it connects to the new IoT blynk.cloud servers, provided it sees:
#define BLYNK_TEMPLATE_ID "Your template ID in here" as the first line of your sketch.
This isnāt working, because youāve left this line commented-out, rather than pasting your credentials from the firmware configuration screen for the device in the web console.
Probably because the Blynk.begin process with IoT requires a template ID to be passed to the server as part of the connection negotiation process, and you havenāt provided one in your sketch.
I had the same problem. In my case it worked when I used the Library version 1.0.1. The newest 1.1.0 caused the same WatchDog errors on my NodeMCU. I was using the latest ESP8266 Core (version 3.1.0)
It was also very important to have the template ID as the first line (even before any include), which was mentioned here before.
Please fix this issue with the version of the library and the NodeMCU (maybe even other ESP8266, have“t tested it though)
Are you using any Digital datastreams?ā¦
you are right that was the problem. I didn“t realize it but I changed the datastreams the same time I changed the version. It now works with the latest version when only using virtual datastreams.
