Esp8266+dht22 temperature and humidity reading in serial
#include <Adafruit_Sensor.h>
#include <DHT.h>
#define DHTPIN 5 //pin gpio 5 in sensor
#define DHTTYPE DHT22   // DHT 22 Change this if you have a DHT11
DHT dht(DHTPIN, DHTTYPE);
char auth[] = "I0D_a0yjzD1ObkIiMAIkrNUi8Ax_bXB6";  // Put your Auth Token here. (see Step 3 above)
   Blynk.begin(auth, "DIGI-vC3w", "094159846"); //insert here your SSID and password
void sendUptime()
   //Read the Temp and Humidity from DHT
  float h = dht.readHumidity();
    Blynk.virtualWrite(V10, t); // virtual pin
  Blynk.virtualWrite(V11, h); // virtual pin
  Serial.print("T=");
  Serial.println(t);
  Serial.print("H=");
  Serial.println(h);
I get strange readings of temperature and humidity.
In another code for displaying as html it displays me well.
I use the same DHT library.
In the code above it displays temperature 10.20 and humidity 3340.00
And with another code it displays 23.00 for temperature and humidity 50.40%
@Dalibor_Stefanovici please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code so that it displays correctly.
I hope it’s OK
No, instead of copying and pasting the triple backticks that I provided you’ve used blockquotes instead.
Try again.
Fixed issue, error was from SimpleTimer.h.
Thank you.
I think the requests with this sensor ?
are too frequent ? Try with 5000L !?
Sorry, i did not see the “solved” status ! :wink:
