ESP8266 DHT11 Notification Support
Hello
When I receive a notification from the sensor, I want the next notification to come when the value in the sensor changes. If the notification came at 25 C, I want the next notification to come at 26 C. Can you help me?
#include <DHT.h>
char auth[] = "";
char ssid[] = "";
char pass[] = "";
#define DHTPIN 4          // What digital pin we're connected to
#define DHTTYPE DHT11     // DHT 11
//#define DHTTYPE DHT22   // DHT 22, AM2302, AM2321
//#define DHTTYPE DHT21   // DHT 21, AM2301
DHT dht(DHTPIN, DHTTYPE);
void sendSensor()
 float nem = dht.readHumidity();
 float sicaklik = dht.readTemperature(); // or dht.readTemperature(true) for Fahrenheit
 if (isnan(nem) || isnan(sicaklik)) {
   return;
 Blynk.virtualWrite(V1, nem);
 Blynk.virtualWrite(V0, sicaklik);
void sendAlert()
  if(sicaklik > 26)
   Blynk.notify(String("Sıcaklık Yüksek ")+sicaklik + String("°C"));
 //Blynk.begin(auth, ssid, pass, "blynk.cloud", 80);
 dht.begin();
 timer.setInterval(5000L, sendSensor);
 timer.setInterval(60000L, sendAlert);
I’d suggest that you use a variable to store the value when you sent the last notification, then compare the latest reading with that value. If the latest reading If the latest reading is >= the last notified reading +1 then send a new notification and update the last notified value.
Could you please post a sample code ?
I’m not going to write your code for you, because you won’t learn if I do.
Modify your code as I’ve suggested, and add-in some serial print statements to help you understand what is happening with your variable values.
If you still have problems then post your updated code and details of what your serial monitor is showing you.
