Hello
i am new… so please bear with me if the code is not good
My project is to monitor two area with DHT11 an to see those value over the web with the Blynk app on a iOs phone
It with a ESP8266 and DHt11
the code is running but after few hour it stop… the esp8266 get disconnected from my home internet
Any help would be appreciated
// Example testing DHT11 humidity/temperature sensors
// Demonstrates multiple Temperature sensors
#include <DHT.h>
#define DHT1TYPE DHT11 // Using Temperature Type = DHT11//
#define DHT4PIN 4 // what pin we're connected to ?//
#define DHT2PIN 2 // what pin we're connected to ?//
// Auth Token in the Blynk App.
char auth[] = "TTTT"; //Enter the Auth code which was send by Blink
char ssid[] = "XXX"; //Enter your WIFI Name
char pass[] = "ZZZZ"; //Enter your WIFI Password
DHT dht4(DHT4PIN, DHT1TYPE);
DHT dht2(DHT2PIN, DHT1TYPE);
//Connection process
//Serial.println("Connection in Process Please Wait");
dht4.begin();
dht2.begin();
// Reading temperature or humidity
delay(2000);
float h1 = dht2.readHumidity();
float t1 = dht2.readTemperature();
float h2 = dht4.readHumidity();
float t2 = dht4.readTemperature();
// check if returns are valid, if they are NaN (not a number) then something went wrong!
if (isnan(t1) || isnan(h1))
//Serial.println("Failed to read from DHT #1");
//Serial.print("Temperature 1 = ");
//Serial.print(t1,0);
//Serial.print(" C");
//Serial.print(" Humidity 1 = ");
//Serial.print(h1,0);
//Serial.println(" %\t");
if (isnan(t2) || isnan(h2))
//Serial.println("Failed to read from DHT #2");
//Serial.print("Temperature 2 = ");
//Serial.print(t2,0);
//Serial.print(" Humidity 2 = ");
//Serial.print(h2,0);
// Sending Blynk values.
Blynk.virtualWrite(V5, h1); //V5 is for Humidity
Blynk.virtualWrite(V6, t1); //V6 is for Temperature
Blynk.virtualWrite(V7, h2); //V7 is for Humidity
Blynk.virtualWrite(V8, t2); //V8 is for Temperature
