Esp8266 crash, exception and restart when write blynk property
Hi everyone.
The following method cause my esp8266 exception error and reboot when i press the button vpin 100
if i uncomment the line Blynk.virtualWrite(V73, 1023) or Blynk.virtualWrite(V73, 0);
v73 is a led on blynbk app. D8 high will close an external relay to start the fan. I really dont know why this happen. Any suggestion for this? Thanks
BLYNK_WRITE(V100) {
  int pinValue = param.asInt();
  if (pinValue == 1)
    digitalWrite(D8, HIGH);
   // Blynk.virtualWrite(V73, 1023);
    digitalWrite(D8, LOW);
  //  Blynk.virtualWrite(V73, 0);
You don’t need to Blynk.virtualwrite() to the Blynk LED Widget. Have a look at the LED Widget example sketch to see how you use it.
https://examples.blynk.cc/?board=ESP8266&shield=ESP8266%20WiFi&example=Widgets%2FLED%2FLED_Blink
You declare the widget:
WidgetLED led1(V1);
Then simply turn it On or Off:
led1.off();
led1.on();
Use the eamples
cul
billd
The LED widget has 256 brightness levels (0-255) so Blynk.virtualWrite(V73, 255); is what you’d normally use to turn an LED widget on to maximum brightness if you are using the virtualWrite approach as opposed to the led1.on() approach described by Bill.
Thank you Bill and Pete
your helps solve my problems
Regards
WidgetLED fanled(V23);
 WidgetLED lcdled(V21);
 BLYNK_WRITE(V100) {
 if (pinValue == 1)
fanled.on();// system crash  , exception after 1 or 2 times button pressed
fanled.off();  //system crash  , exception after 1 or 2 times button pressed
but if i place this line fanled.on(); or fanled.off(); inside loop , it works without any problem.
this code is inside loop()
 if (digitalRead(D8) == HIGH)
 Blynk.virtualWrite(V100, 1);//toggle the button
 fanled.on();
    Blynk.virtualWrite(V100, 0);//toggle the button
    fanled.off();
@Anthony_Chen please edit your post and use triple backticks at the beginning and end of your code, and remove the ‘>’ characters at the beginning of each line of code.
What exactly is the exception error that you get when the crash occurs?
Have you tried decoding it with the exception decoder?
