ESP8266 Blynk.email
I followed installation instructions, used correct libs, and programmed ESP8266 (no Arduino) OK to send an email message using:
Blynk.email(“My@email”, “Blynk_test01”, “My Blynk project is online.”);
and also noticed the comment in:
“sending-email-without-the-app-in-play-mode/2747”
However, did not succeed. I did receive the “Auth Token for my project” by email.
What could be wrong?
Thanks!
I suppose you are using Blynk Cloud? Right? Please post your code here.
Yes I do use the cloud + app, I have the app running on an iPhone. When running the code (below) on an ESP8266 I did get positve responses and 1 ms pings, but no email message sent.
Today I got a response:
[53195] Connecting to cloud.blynk.cc:8442
[53390] Invalid auth token
and my email + password for the app do not match anymore. I did reset the password, but was not able to log in. I will wait and try again later. My code:
/#define BLYNK_PRINT Serial
/#include ESP8266WiFi.h
/#include BlynkSimpleEsp8266.h …// left out the <> here , messes up the layout in the post
// set up Wifi
const char* ssid = “xxx”; // taken out for this post
const char* password = “xxx”; // taken out for this post
// Create an instance of the server, specify the port to listen on as an argument
WiFiServer server(80);
WiFiClient client;
// You should get Auth Token in the Blynk App. Go to the Project Settings (nut icon).
char auth[] = “xxx”; // taken out in this post
// Connect to WiFi network
Serial.println();
Serial.println(ssid);
WiFi.begin(ssid, password);
delay(500);
Serial.print(".");
Serial.println("");
Serial.println(“WiFi connected”);
// Start the server
server.begin();
Serial.println(“Server started”);
// Print the IP address
Serial.println( WiFi.localIP());
Blynk.begin(auth, ssid, password);
// Wait until connected
// Send e-mail when your hardware gets connected to Blynk Server
Blynk.email(“My_email@address”, “Blynk_test01”, “My Blynk project is online.”); // does not happen …
Serial.println(“Blynk.run();”);
Blynk.email("gert3d@yahoo.com", “Blynk_test01”, “My Blynk project is online.”);
Serial.println(“Blynk.email();”);
delay(200000);
// *** WARNING: You are limited to send ONLY ONE E-MAIL PER MINUTE! ***
Sending in loop not recommended. See our examples how to avoid this. Also you may have wrong email or email that filter Blynk email, there are a lot of possible reasons. Try to send to another account for check.
We had an issue recently for newly created users. You have to recreate account. Sorry for inconveniences.
