Hi There,
I am using Blynk with ESP8266, DHT22 3PIN, Capacitive Soil moisture Sensor v1.2 & Water pump.
I would like to water my plan based on the moisture sensor condition.
also, i want my DHT22 to read the humidity & temperature and populate to my Blynk app
I have try similar project with Arduino + Soil moisture & water pump that’s works.
but using ESP8266 is giving an error.
Please, any advice?
below is the code.
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
#include <DHT.h>
char pass[] = "YourPassword";
#define WATER_PUMP 27
boolean state = false;
#define DHTPIN 2 // D4
//#define DHTTYPE DHT11 // DHT 11
#define DHTTYPE DHT22 // DHT 22, AM2302, AM2321
//#define DHTTYPE DHT21 // DHT 21, AM2301
DHT dht(DHTPIN, DHTTYPE);
void sendSensor()
float h = dht.readHumidity();
if (isnan(h) || isnan(t)) {
return;
Blynk.virtualWrite(V5, t);
Blynk.virtualWrite(V6, h);
pinMode(WATER_PUMP, OUTPUT);
dht.begin();
BLYNK_WRITE(V1)
if (state == false) {
state = true;
Blynk.notify("You just watered your plant.");
digitalWrite(WATER_PUMP,HIGH);
else {
state = false;
digitalWrite(WATER_PUMP,LOW);
