Esp8266 + Blynk + Button
Light switch
This beautiful code is in all of my light switch but can not finish so that you can beat the light off with the button on the switch
Етот код стоит во всех моих Выключателей Света но не могу доделать так чтоб можна било свет выключить с кнопки на самом выключателе
    #include <OneWire.h>
    #include <TimeLib.h>
    #define Thermometer 10
    // Pin 10 - Gpio 10
    OneWire oneWire(Thermometer);
    char auth[] = "cb9e0b23ca35429882f6a6658713174e";
      Blynk.begin(auth, "Tp-link", "Ms0606400");
      sensors.begin();
      timer.setInterval(2000L, sendTemps);
    void sendTemps()
      float tempBabyRoom = sensors.getTempCByIndex(0);
      Blynk.virtualWrite(0, tempBabyRoom);
Here’s the code for the button
int Rele=0;
  pinMode(8,OUTPUT);
  pinMode(11,INPUT);
  if (digitalRead(11)==1 && Rele ==0)
       digitalWrite(8,HIGH);
       Rele =1;
       while (digitalRead(11))
         delay(50);
   if (digitalRead(11)==1 && Rele ==1)
       digitalWrite(8,LOW);
       Rele =0;
         delay(50);
Help dining in one code
@Mindezek we have ready examples for your case. Look here :
https://github.com/blynkkk/blynk-library/blob/master/examples/More/SyncPhysicalButton/SyncPhysicalButton.ino
https://github.com/blynkkk/blynk-library/blob/master/examples/More/ButtonInterrupt/ButtonInterrupt.ino
https://github.com/blynkkk/blynk-library/blob/master/examples/More/ButtonPoll/ButtonPoll.ino
All links are invalid
ERROR 404
@safari if you are using the Arduino IDE you have all the examples on your computer and can access them in the IDE.
If you are not using the Arduino IDE or an example becomes available in the master branch before an official release you should familiarise yourself with Blynk’s GitHub.
Just start at https://github.com/blynkkk/blynk-library and explore.
I’ve found it in more/sync/… thanks!
