hi
So recently i found that in examples for Blynk when I go to: More-> DirectConnect, there is example called “ESP8266_AccessPoint” which is kinda weird because I tought that blynk has to have internet connection on phone to send data through server, although I want to create an blynk controlled servo motor which i can access through ESP via WiFi connection. So i uploaded it and the Acces Point is up and I can connect, but here comes the actual problem, when I am connected to this WiFi through phone I cant send any data to blynk servers which leaves me with uselles WiFi station.
Any ideas maybe how to switch blynk app to offline mode or maybe I misunderstood this example?
Kindly waiting for feedback
I am using iOs and ESP8266-01
(Posted it in issues and errors because i think that this example is the problem)
Code:
#include <ESP8266WebServer.h>
char auth[] = "yOlUZgiNWIGJUI1AadTqMdRQ7CWtT1F_";
// This device Access Point credentials.
// Set password to "" to create open network.
const char* ssid = "RTD_0.1";
const char* pass = "maciej333";
WiFiServer wifiServer(80);
WiFiClient wifiClient;
// This function tries to reconnect to WiFi network
void connectWiFi() {
Serial.print("Configuring access point...");
if (pass && strlen(pass)) {
WiFi.softAP((char*)ssid, (char*)pass);
WiFi.softAP((char*)ssid);
wifiServer.stop();
wifiServer.begin();
Serial.print("Server started: ");
Serial.println(WiFi.softAPIP());
BLYNK_WRITE(V1)
int j1_x = param[0].asInt();
int j1_y = param[1].asInt();
Serial.println(j1_x);
BLYNK_WRITE(V0)
int j2_x = param[0].asInt();
int j2_y = param[1].asInt();
Serial.println(j2_x);
connectWiFi();
// If thereis some client
wifiClient = wifiServer.available();
if (wifiClient)
Serial.println("client available");
Blynk.begin(wifiClient, auth);
while (wifiClient.connected())
