Hi friends. I have a problem with compiling my sketch. the problem is when I add widgetRTC to my sketch the arduino IDE showing error. how can I fix this problem
here my sketch:
//Master Controller for Bosch and Siemens
#include <WidgetRTC.h>
#include <ESP8266mDNS.h>
#include <WiFiUdp.h>
#include <ArduinoOTA.h>
char auth[] = "QRZQrO4sxt7cIbIGR-_GVgbRY-wOoUjb";
char ssid[] = "MikroTik Tesla";
char pass[] = "12345678";
char server[] = "10.5.51.5";
char hostOTA[] = "Master";
char currentTime[9];
char startTime[9];
char stopTime[9];
int SThour;
int STmin;
int STsec;
int SPhour;
int SPmin;
int SPsec;
int tempmicakhar;
int hummicakhar;
int premicakhar;
int pirmicakhar;
const int Relay = 14;
WidgetBridge bridge1(V100);
WidgetBridge bridge2(V101);
WidgetRTC rtc;
Blynk.begin(auth, ssid, pass, server, 8080);
ArduinoOTA.setHostname(hostOTA);
ArduinoOTA.begin();
rtc.begin();
pinMode(Relay, OUTPUT);
setSyncInterval(360);
timer.setInterval(30000L, TimeCheck); // Update Time Check every 30 seconds
BLYNK_CONNECTED()
bridge2.setAuthToken("TWyLDt5xgR57gTPCQB0vt7yZjNnke9Tl");
BLYNK_CONNECTED() {
Blynk.syncVirtual(V98);
TimeCheck();
BLYNK_WRITE(V98) {
TimeInputParam t(param);
SThour = t.getStartHour();
STmin = t.getStartMinute();
STsec = t.getStartSecond();
SPhour = t.getStopHour();
SPmin = t.getStopMinute();
SPsec = t.getStopSecond();
BLYNK_WRITE(V99)
int pinValue = param.asInt();
if (pinValue == 1)
digitalWrite(Relay, HIGH);
bridge2.virtualWrite(V0, 1);
else if (pinValue == 0)
digitalWrite(Relay, LOW);
bridge2.virtualWrite(V0, 0);
BLYNK_WRITE(V1)
tempmicakhar = param.asInt();
BLYNK_WRITE(V2)
hummicakhar = param.asInt();
BLYNK_WRITE(V3)
premicakhar = param.asInt();
BLYNK_WRITE(V4)
pirmicakhar = param.asInt();
void TimeCheck() { // call with timer every 30 seconds or so
// Get RTC time
sprintf(currentTime, "%02d:%02d:%02d", hour(), minute(), second());
Serial.print("Current Time: ");
Serial.println(currentTime);
// Get Time Input Widget time
sprintf(startTime, "%02d:%02d:%02d", SThour, STmin, STsec);
Serial.print("Start Time: ");
Serial.println(startTime);
sprintf(startTime, "%02d:%02d:%02d", SPhour, SPmin, SPsec);
Serial.print("Stop Time: ");
if (hour() == SThour) {
if (minute() == STmin) {
Serial.println("Doing something now");
digitalWrite(Relay, HIGH); // Turn ON built-in LED
} else if (minute() < STmin) {
Serial.println("Will do something");
} else if (minute() > STmin) {
Serial.println("Did something");
Serial.println("Clueless");
if (hour() == SPhour) {
if (minute() == SPmin) {
Serial.println("Stopping something now");
digitalWrite(Relay, LOW); // Turn OFF built-in LED
} else if (minute() < SPmin) {
Serial.println("Will stop something");
} else if (minute() > SPmin) {
Serial.println("Stopped something");
Serial.println("----------");
ArduinoOTA.handle();
and the error:
Multiple libraries were found for "ArduinoOTA.h"
Used: C:\Users\STRIX\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.2\libraries\ArduinoOTA
Not used: C:\Users\STRIX\Documents\Arduino\libraries\ArduinoOTA
exit status 1
Error compiling for board NodeMCU 1.0 (ESP-12E Module).
thanks.
