ESP8266-01disconnect and connect
Hi!
I am using the using the ESP8266-01, but it connects then disconnects continuously in the APP. I try to turn on a led an to send an email , but only it work sometimes.I dont now which is the probem.
I am using Arduino leonardo and i choose the next figures:
Arduino LEONARDO with ESP8266-01
Blynk 2.27.1 version
APP settings:HADWARE MODEL:ARDUINO LEONARDO
CONNECTION TYPE:WIFI
ARDUINO SETTING:BOARD:ARDUINO LEONARDO
#include <ESP8266_Lib.h>
char auth[] = "3859c00afb3b4ddeabeac179be498541";
char ssid[] = "WIFI ";
char pass[] = "946255638";
SoftwareSerial EspSerial(10, 11); // RX, TX
// Your ESP8266 baud rate:
#define ESP8266_BAUD 115200
ESP8266 wifi(&EspSerial);
  // Set ESP8266 baud rate
  //Blynk.begin(auth, wifi, ssid, pass, "blynk-cloud.com", 80);
  //Blynk.begin(auth, wifi, ssid, pass, IPAddress(192,168,1,100), 8080);
Far too fast for softwareSerial.
Set your ESP-01 to 9600 using an AT command and use that in your sketch.
Also, make sure you’re using a separate, beefy, PSU for your ESP and that’s you connect the grounds together with your Arduino PSU.
now is working
thank you for your advice
