Hello ,
I`m trying to connect blynk with ESP8226 01 with local server
device - Ardunio mini MEGA , ESP8226 01 Shield (ATcommand)
connection type - wifi
local server (running in google cloud)
My problem is that I do not know how to set IP of local server into ESP or Blynk.begin function . When I run my program with default Blynk cloud my connection is perfect .
But I can not crate connection with local server .
I tryed calling Blynk.begin function like :
Blynk.begin(auth, wifi, ssid, pass, "34.65.191.76");
or
Blynk.begin(auth, wifi, ssid, pass, "34.65.191.76",9443);
also
char server [] = "34.65.191.76";
Blynk.begin(auth, wifi, ssid, pass, server);
or
char port[]="9443";
Blynk.begin(auth, wifi, ssid, pass, server, port);
I tryed also to change β.β to β,β but did not help.
My local server should be fine becouse I can connect to it with phone and manage it via admin settings in google.
My project is long and it is not in english so I will post example that I used to connect with Blynk , the example is in library Blynk\examples\Boards_WiFi\ESP8266_Shield
#include <ESP8266_Lib.h>
char pass[] = "YourPassword";
#define EspSerial Serial1
//#include <SoftwareSerial.h>
// Your ESP8266 baud rate:
#define ESP8266_BAUD 115200
ESP8266 wifi(&EspSerial);
// Set ESP8266 baud rate
My output in Serial console look like this :
[3178]
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ \/ '_/
/____/_/\_, /_//_/_/\_\
/___/ v0.6.1 on Arduino Mega
[3771] Connecting to MyWifi
[6816] AT version:1.3.0.0(Jul 14 2016 18:54:01)
SDK version:2.0.0(656edbf)
compile time:Jul 19 2016 18:44:44
OK
[13929] +CIFSR:STAIP,"myIP"
+CIFSR:STAMAC,"myMAC"
[13938] Connected to WiFi
Program stopps after " [13938] Connected to WiFi"
Thank you for reply or reading . If this problem was already discoused or solved somewehere I m realy sorry for reposting it again , I tryed to find solution before postin but with no success thank you .
