Hey guys
I´m have some trouble to fix a error
the code works fine but afer a few hours the esp 32 stop working and change the state of my relay
the code is:
#include <Adafruit_Sensor.h>
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
#include <ThingSpeak.h>
#include <DHT.h>
#include <DHT_U.h>
#include <Wire.h>
#include <OneWire.h>
#include <WidgetRTC.h>
#include <TimeLib.h>
//const char* server = "api.thingspeak.com";
WiFiClient client;
#define CHANNEL_ID ########
#define CHANNEL_API_KEY "##########"
#define BLINK_ID "#######"//JOAO
char ssid[] = "#####";
char pass[] = "32734755";
int nivel = 25;
int valueNivel = 0;
const int oneWireBus = 4; //Sensor de temperatura da agua
OneWire oneWire(oneWireBus);
int Photo = 33; //Sensor de Luz canal digital
int valuePhoto = 0;
#define DHTTYPE DHT22 //Sensor Umidade do AR e Temperatura
#define DHTPIN 19
DHT dht(DHTPIN, DHT22);
float localHum = 0;
float localTemp = 0;
WidgetRTC rtc;
WidgetTerminal terminal(V4);
int switchState;
int rele1 = 32; //Luz Posiçao 2
int rele2 = 26; // Bomba Posiçao 3
int rele3 = 18; //Exautao Posiçao 4
int horas = hour();
int valor = LOW; // Ver. se luz esta apagada
BLYNK_CONNECTED() {
// Synchronize time on connection
rtc.begin();
BLYNK_WRITE(V6){
switchState = param.asInt();
getLUX();
ThingSpeak.begin(client); // Initialize ThingSpeak
pinMode(rele1, OUTPUT); // definições das portas IN1 e IN2 como portas de saidas
pinMode(rele2, OUTPUT);
pinMode(rele3, OUTPUT);
pinMode(Photo, INPUT);
pinMode(nivel, INPUT);
digitalWrite(rele1, valor); // desativa porta IN1
digitalWrite(rele2, HIGH);
digitalWrite(rele3, HIGH);
dht.begin();
Wire.begin(21,22); //sda Roxo scl Cinza
delay(3000);
timer.setInterval(30100L, getDHT);
timer.setInterval(30200L, getTempagua);
timer.setInterval(30300L, clockDisplay);
timer.setInterval(30400L, getNivel);
timer.setInterval(30500L, getPhoto);
timer.setInterval(30600L, getLUX);
timer.setInterval(21600000L, getRestart);// reseta em 12 horas
terminal.clear();
Serial.println(ssid);
WiFi.begin(ssid, pass);
int wifi_ctr = 0;
delay(500);
Serial.print(".");
Blynk.begin(BLINK_ID, ssid, pass);
void loop(){
void getTempagua(){ // temp checks
sensors.requestTemperatures();//Colete informações de temperatura
float tempAgua = sensors.getTempCByIndex(0);//Obtenha a temperatura em graus Celsius
Serial.print("Temp. agua: ");
Serial.print(tempAgua);
Serial.println(" ");
Blynk.virtualWrite(V0, tempAgua);//Atualize variaveis Blynk com os valores de temperatura
ThingSpeak.setField(3,tempAgua);
ThingSpeak.writeFields(CHANNEL_ID,CHANNEL_API_KEY);
void getPhoto(){ // check the light status with ldr sensor
valuePhoto = digitalRead(Photo);
if(valuePhoto == 1){ // say off
Blynk.virtualWrite(V1, "Desligada");
else{ // say on
Blynk.virtualWrite(V1, "Ligada"); //Luz desligada
Serial.print("Luz (0 Ligada; 1 Desligada: )");
Serial.print(valuePhoto);
terminal.print("Luz (0 Ligada; 1 Desligada: )");
terminal.print(valuePhoto);
terminal.println(" ");
terminal.flush();
void getDHT(){ // temp and humi sensor . turn on and off the exhaust fan
float tempIni = localTemp;
float humIni = localHum;
localTemp = dht.readTemperature();
localHum = dht.readHumidity();
Serial.print("TEMPERATURA: ");
Serial.print(localTemp);
Serial.println("C");
Serial.print("UMIDADE: ");
Serial.print(localHum);
Serial.println("%");
if(localTemp > 26 || localHum > 50){ // turn on if the temp is higher than 26 C and/or the hum is higher than 50%
else{ // turn on if not
digitalWrite(rele3, LOW);
Blynk.virtualWrite(V2, localTemp); // write blynk
Blynk.virtualWrite(V3, localHum); // write blynk
ThingSpeak.setField(1,localHum); //set the channel 1 to say the hum value
ThingSpeak.setField(2,localTemp); //set the channel 2 to say the tem value
ThingSpeak.writeFields(CHANNEL_ID,CHANNEL_API_KEY); // write on thingspeak
void clockDisplay(){
Serial.print("Hora e data: ");
Serial.print(currentTime);
Serial.print(" ");
Serial.print(currentDate);
Serial.println();
terminal.print("Hora e data: ");
terminal.print(currentTime);
terminal.print(" ");
terminal.println(currentDate);
terminal.flush();
Blynk.virtualWrite(V4, currentTime); // write blynk
void getLUX() { // Lê a condiçao da selecao de 4 opcoes no app
Serial.print("verificar horas : ");
Serial.print(hour());
Serial.println();
if (switchState == 1){ // select working hours
if(hour() == 6 && hour()<= 18 ){// working hours 6 am to 6 pm; 12 hours cycle
valor = LOW;
else{
valor = HIGH;
if (switchState == 2){ // select working hours
clockDisplay();
if(hour() == 5 && hour() <= 23 ){//working hours 5 am to 11 pm; 18 hours cycle
valor = LOW;
else{
valor = HIGH;
if (switchState == 3){ // turn off the light
valor = HIGH;
if (switchState == 4){ // turn on the light
valor = LOW;
ThingSpeak.setField(4,valor); //set the channel 4 to say the relay status
ThingSpeak.writeFields(CHANNEL_ID,CHANNEL_API_KEY);// write on thingspeak
Serial.print("Verificar estado do Rele da luz (0 Ligada; 1 Desligada) : ");
Serial.print(valor);
Serial.println();
terminal.print("Verificar estado do Rele da luz;;/; (0 Ligada; 1 Desligada) : ");
terminal.print(valor);
terminal.flush();
void getNivel(){ //turn off the pump if water is low
valueNivel = digitalRead(nivel);
if(valueNivel == 0){
Blynk.virtualWrite(V7, "Ligada");
else{
digitalWrite(rele2, LOW);
Blynk.virtualWrite(V7, "Desligada");
Serial.print("Agua (0 Ligada; 1 Desligada) : ");
Serial.print(valueNivel);
Serial.println();
terminal.print("Agua (0 Ligada; 1 Desligada) : ");
terminal.print(valueNivel);
terminal.flush();
void getRestart(){ // restart esp32
Serial.println("Restarting ");
ESP.restart();
the trouble are when the segment state are set in the app and suddenly change the relay state.
Look like this
i turn on the esp 32 and the switch state are press 1 on the app. Work fine for 2 or 3 hours and suddenly the light turn off when should be on.
the operating period is 12 hours on and 12 hours off on the case 1.
I’m not sure what i did wrong.
Serial.println();
valor = LOW;
else{
valor = HIGH;
clockDisplay();
valor = LOW;
else{
valor = HIGH;
valor = HIGH;
valor = LOW;
Serial.println();
terminal.flush();
can u guys help me?
