BLYNK
BLYNK.IO       📲 GETTING STARTED       đź“— DOCS       👉 SKETCH BUILDER
ESP32 SIM800L can't connect to new platform
Hi, I am trying to connect ESP32 SIM800L to new blynk platform. I am using the sletch from the examples:
/* Fill-in your Template ID (only if using Blynk.Cloud) */
#define BLYNK_TEMPLATE_ID "TMPL23T-oMFk"
#define BLYNK_DEVICE_NAME "Entra Energy"
// Select your modem:
#define TINY_GSM_MODEM_SIM800
//#define TINY_GSM_MODEM_SIM900
//#define TINY_GSM_MODEM_M590
//#define TINY_GSM_MODEM_A6
//#define TINY_GSM_MODEM_A7
//#define TINY_GSM_MODEM_BG96
//#define TINY_GSM_MODEM_XBEE
// Default heartbeat interval for GSM is 60
// If you want override this value, uncomment and set this option:
//#define BLYNK_HEARTBEAT 30
#include <TinyGsmClient.h>
char auth[] = "ag1p2OnHsvHusY3-ZsOYAjuOgTsMXyxS";
// Your GPRS credentials
// Leave empty, if missing user or pass
char apn[]  = "internet.vivacom.bg";
char user[] = "";
char pass[] = "";
long currentMillisSend = 0;
long previousMillisSend = 0;
long intervalSend = 5000;
int counter = 0;
// Hardware Serial on Mega, Leonardo, Micro
#define SerialAT Serial1
// or Software Serial on Uno, Nano
//#include <SoftwareSerial.h>
//SoftwareSerial SerialAT(2, 3); // RX, TX
TinyGsm modem(SerialAT);
  // Set GSM module baud rate
  SerialAT.begin(115200);
  delay(3000);
  modem.restart();
  // Unlock your SIM card with a PIN
  //modem.simUnlock("1234");
  unsigned long currentMillisSend = millis();
  if(currentMillisSend - previousMillisSend > intervalSend)
    counter = counter + 1;
    Blynk.virtualWrite(V1, counter);
  previousMillisSend = currentMillisSend;
The sketch is uploaded to the device, but the serial monitor shows errors:
ts Jun  8 2016 00:22:57
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0018,len:4
load:0x3fff001c,len:1216
ho 0 tail 12 room 4
load:0x40078000,len:10944
load:0x40080400,len:6388
entry 0x400806b4
Also the device wont to connect to the platform
Thank you very much for your help!
What board type did you select in the IDE ?
TTGO T1. It working properly and connects to cellular if i dont use blynk
Hello, were you able to solve it?
@Misinino I’d suggest that you start a new “need help with my project” topic, and provide as much details as possible.
Hi, I decided to use mqtt and Node-Red as a “bridge” to communicate with the blynk platform.
