When you use interrupts, there are a couple of things that you should keep in your mind.
You should keep the ISR (interrupt service routine) as short as possible.
Avoid blocking functions, like delays.
Avoid serial prints.
Avoid non-reentrant function calls.
Don’t declare any non-static variables inside the handler.
Avoid operations that involve dynamic memory allocations.
You can search the web for more details.
