I’m using an Esp32 wroom module and installed the example from Blynk.Edgent ,
the charging for the module is normal, the connection to the wifi network is also normal,
but when I type in the browser 192.168.4.1, it returns me " Not Found:/ " ,
I’ve tried in other modules but it always returns the same message.
I used it with the Esp8266 module and it worked normally, only with Esp32 it gives this error.
If you can help me
example code used:
#define BLYNK_TEMPLATE_ID "TMPLkCGRGtGQ"
#define BLYNK_DEVICE_NAME "Camanducaia"
//#define BLYNK_DEBUG
#define APP_DEBUG
// Uncomment your board, or configure a custom board in Settings.h
//#define USE_WROVER_BOARD
//#define USE_TTGO_T7
//#define USE_ESP32C3_DEV_MODULE
//#define USE_ESP32S2_DEV_KIT
#include "BlynkEdgent.h"
delay(100);
BlynkEdgent.begin();
BlynkEdgent.run();
Error displayed in serial port and browser :
