Hi John, mine doesn’t quite look like yours, see screen shot, I did install the ESP32 Arduino 2.0.4 but I don’t get the same end screen as you. Am I missing something here?
I am also using the new Arduino IDE V2.0.9 …
And I can confirm it is not 100% stable. (Today I can’t open the boards manager, for instance …)
=> And there is “often” problems with downloading sketches as there is some “constant” problem with the serial port management in the new Arduino IDE V2. )
If having problems - do install the (still) official version 1.8.n
May be or may not be.
There are instances where older cores tends to be more stable and reliable when compared to newer cores. So we need to play around with cores and see which one works for you.
Also try to create a hotspot on your smartphone with simple SSID and PASSWORD like
SSID = ABCD
PASS = 12345678
See if this works. As @jonas said SSID’s with spaces may not work well with esp32.
By following what i said. You may rule out one aspect of why the module is not connecting.
Uninstalling the arduino ide and all the associated files and reinstalling ide ,cores and libraries have solved problems many times.
Meanwhile if possible buy a new esp32 module or ask your friend to lend one. If it works, then your module has gone bad.
Actually, I’ve been using the latest version of the esp32 core for a while without any issues, so I know it’s not a core issue, and I’ve been using SSID with spaces, so that shouldn’t be an issue either.
The first thing you should do is try a different esp32 board.
Hi, well I tried the phone hot spot idea and it seems to be working. To clarify my hot spot ssid does have a space in it “HUAWEI P30” , and serial monitor shows it is connected, and to my delight the Blynk console on laptop and app shows 1x active device.
So my question here is , is my board still defective or is my Wifi router the issue. If Wifi router what test could I try to see what probable cause is, note every other device in the house works fine off this router?
This is a simple demo of sending and receiving some data.
Be sure to check out other examples!
#define BLYNK_TEMPLATE_ID "TMPLQPQz8rzC"
#define BLYNK_DEVICE_NAME "Quickstart Template"
#define BLYNK_AUTH_TOKEN "ROm1XzZNz8BMEEFeWQN4LA0JD2FRJ6g8"
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
char ssid[] = "HUAWEI P30";
char pass[] = "7a7312850689";
// This function is called every time the Virtual Pin 0 state changes
BLYNK_WRITE(V0)
// Set incoming value from pin V0 to a variable
int value = param.asInt();
// Update state
Blynk.virtualWrite(V1, value);
// This function is called every time the device is connected to the Blynk.Cloud
BLYNK_CONNECTED()
// Change Web Link Button message to "Congratulations!"
Blynk.setProperty(V3, "offImageUrl", "https://static-image.nyc3.cdn.digitaloceanspaces.com/general/fte/congratulations.png");
Blynk.setProperty(V3, "onImageUrl", "https://static-image.nyc3.cdn.digitaloceanspaces.com/general/fte/congratulations_pressed.png");
Blynk.setProperty(V3, "url", "https://docs.blynk.io/en/getting-started/what-do-i-need-to-blynk/how-quickstart-device-was-made");
// This function sends Arduino's uptime every second to Virtual Pin 2.
void myTimerEvent()
Blynk.virtualWrite(V2, millis() / 1000);
//Blynk.begin(auth, ssid, pass, "blynk.cloud", 80);
// to avoid delay() function!
If you try to join the router’s wifi, do you get the exact same error along with the reset? I can’t think of anything that could cause that to happen. For example, if its a wrong password you’d get an error like:
[ 3280][W][WiFiGeneric.cpp:873] _eventCallback(): Reason: 15 - 4WAY_HANDSHAKE_TIMEOUT
If you’re getting a different error with the router, I’d try to join the router’s wifi again, and see if the esp is listed in the attached devices admin panel. If it is, is an security / access control thing that blocks new devices. If it’s not there, the only thing I can think of it to check out the wireless configuration. Packet size (fragmentation) is the only thing that comes to my head I’ve had to change on my router. This is all specific to your exact model router though, you’ll have to find a manual on it.
It’s not a mini - this might be a good example for google’ing the question before replying if you don’t understand. Look up the esp32 mini, you’ll know immediately
