ESP32-CAM Video Stream on Blynk
Sorry to bug you gydota but do you still have the sketch on your ESP32-Cam? Pleeeease!
I use the Blynk ESP32 Cam Example and my link is http://xx.xx.xx.xx:81/stream and using that link on the Blynk App doesnt work in Video Streaming
try it this way
Certainly did try that :slight_smile: but it doesn’t work.
But if i use the link in my browser it works
I wrote above that the ESP 32 CAM allows only one connection. So you need to close the tab in your browser and try again on your smartphone. Sometimes, if there is no flow, Blynk has to stop and start the project again.
Yup i made sure there was nothing else connecting to it but still no luck.
I feel like the sketch i used on the ESP32 Cam is different to the sketch you used or programmed.
This is my code
#include "OV2640.h"
#include <WiFi.h>
#include <WebServer.h>
#include <WiFiClient.h>
#include <AutoWifi.h>
#include "SimStreamer.h"
#include "OV2640Streamer.h"
#include "OV2640.h"
#include "CRtspSession.h"
char ssid[] = ".............";
char pass[] = "..............";
// This board has slightly different GPIO bindings (and lots more RAM)
// uncomment to use
// #define USEBOARD_TTGO_T
 #define USEBOARD_AITHINKER
#ifndef USEBOARD_AITHINKER
//#define ENABLE_OLED //if want use oled ,turn on thi macro
#endif
// #define SOFTAP_MODE // If you want to run our own softap turn this on
#define ENABLE_WEBSERVER
#define ENABLE_RTSPSERVER
// If your board has a GPIO which is attached to a button, uncomment the following line
// and adjust the GPIO number as needed.  If that button is held down during boot the device
// will factory reset.
#define FACTORYRESET_BUTTON 32
#endif
#ifdef ENABLE_OLED
#include "SSD1306.h"
#define OLED_ADDRESS 0x3c
#ifdef USEBOARD_TTGO_T
#define I2C_SDA 21
#define I2C_SCL 22
#else
#define I2C_SDA 14
#define I2C_SCL 13
#endif
SSD1306Wire display(OLED_ADDRESS, I2C_SDA, I2C_SCL, GEOMETRY_128_32);
bool hasDisplay; // we probe for the device at runtime
#endif
OV2640 cam;
#ifdef ENABLE_WEBSERVER
WebServer server(80);
#endif
#ifdef ENABLE_RTSPSERVER
WiFiServer rtspServer(8554);
#endif
#ifdef SOFTAP_MODE
IPAddress apIP = IPAddress(192, 168, 1, 1);
#else
#endif
void handle_jpg_stream(void)
    WiFiClient client = server.client();
    String response = "HTTP/1.1 200 OK\r\n";
    response += "Content-Type: multipart/x-mixed-replace; boundary=frame\r\n\r\n";
    server.sendContent(response);
    while (1)
        cam.run();
        if (!client.connected())
            break;
        response = "--frame\r\n";
        response += "Content-Type: image/jpeg\r\n\r\n";
        client.write((char *)cam.getfb(), cam.getSize());
        server.sendContent("\r\n");
            break;
void handle_jpg(void)
    cam.run();
    response += "Content-disposition: inline; filename=capture.jpg\r\n";
    response += "Content-type: image/jpeg\r\n\r\n";
void handleNotFound()
    String message = "Server is running!\n\n";
    message += "URI: ";
    message += server.uri();
    message += "\nMethod: ";
    message += (server.method() == HTTP_GET) ? "GET" : "POST";
    message += "\nArguments: ";
    message += server.args();
    message += "\n";
    server.send(200, "text/plain", message);
#endif
void lcdMessage(String msg)
  #ifdef ENABLE_OLED
    if(hasDisplay) {
        display.clear();
        display.drawString(128 / 2, 32 / 2, msg);
        display.display();
  #endif
  #ifdef ENABLE_OLED
    hasDisplay = display.init();
    if(hasDisplay) {
        display.flipScreenVertically();
        display.setFont(ArialMT_Plain_16);
        display.setTextAlignment(TEXT_ALIGN_CENTER);
  #endif
    lcdMessage("booting");
    while (!Serial)
    int camInit =
        cam.init(esp32cam_ttgo_t_config);
#else
#ifdef USEBOARD_AITHINKER
        cam.init(esp32cam_aithinker_config);
#else
        cam.init(esp32cam_config);
#endif
#endif
    Serial.printf("Camera init returned %d\n", camInit);
    IPAddress ip;
#ifdef SOFTAP_MODE
    const char *hostname = "devcam";
    // WiFi.hostname(hostname); // FIXME - find out why undefined
    lcdMessage("starting softAP");
    WiFi.mode(WIFI_AP);
    WiFi.softAPConfig(apIP, apIP, IPAddress(255, 255, 255, 0));
    bool result = WiFi.softAP(hostname, "12345678", 1, 0);
    if (!result)
        Serial.println("AP Config failed.");
        Serial.println("AP Config Success.");
        Serial.print("AP MAC: ");
        Serial.println(WiFi.softAPmacAddress());
        ip = WiFi.softAPIP();
#else
    WiFi.begin(ssid, pass);
    while (WiFi.status() != WL_CONNECTED)
        delay(500);
        Serial.print(F("."));
    ip = WiFi.localIP();
    Serial.println(F("WiFi connected"));
    Serial.println(ip);
#endif
    lcdMessage(ip.toString());
    server.on("/", HTTP_GET, handle_jpg_stream);
    server.on("/jpg", HTTP_GET, handle_jpg);
    server.onNotFound(handleNotFound);
    server.begin();
#endif
    rtspServer.begin();
#endif
CStreamer *streamer;
CRtspSession *session;
WiFiClient client; // FIXME, support multiple clients
    server.handleClient();
#endif
    uint32_t msecPerFrame = 100;
    static uint32_t lastimage = millis();
    // If we have an active client connection, just service that until gone
    // (FIXME - support multiple simultaneous clients)
    if(session) {
        session->handleRequests(0); // we don't use a timeout here,
        // instead we send only if we have new enough frames
        uint32_t now = millis();
        if(now > lastimage + msecPerFrame || now < lastimage) { // handle clock rollover
            session->broadcastCurrentFrame(now);
            lastimage = now;
            // check if we are overrunning our max frame rate
            now = millis();
            if(now > lastimage + msecPerFrame)
                printf("warning exceeding max frame rate of %d ms\n", now - lastimage);
        if(session->m_stopped) {
            delete session;
            delete streamer;
            session = NULL;
            streamer = NULL;
    else {
        client = rtspServer.accept();
        if(client) {
            //streamer = new SimStreamer(&client, true);             // our streamer for UDP/TCP based RTP transport
            streamer = new OV2640Streamer(&client, cam);             // our streamer for UDP/TCP based RTP transport
            session = new CRtspSession(&client, streamer); // our threads RTSP session and state
#endif
Amazing!! it worked!
Found a bug with IOS devices… it doesnt stream properly with IOS devices however on android is works 100% fine @PeteKnight
Congratulation!!!:grinning:
What is the bug? Please report to @Eugene
Thanks.
The video streaming widget flashes the camera footage for a split second and stops buffering. However on an Android device it streams perfectly.
I know is IOS issue because i tested it on 2 IOS devices @Pavel
This will be the first code to upload once they arrive!
Thanks for sharing.
Do you have a working public stream url you can share with me for testing?
I can do some port forwarding and PM you the address if thats fine?
If LAN can work, then install “zerotier” on the router and mobile phone to connect to the external network, no static ip is required.
I have static IP
At least @gydota is using static IP… :sweat_smile:
Hello good morning, I have two ESP32Cam modules configured with the Arduino web server example and with their individual IP addresses which by entering them in the browser I can view and configure.
The problem I have is that I have been trying to configure the video settings widget in the application on my iOS mobile device for a few days by entering the IP in the url address section
http :: //XX.XX.XX.XX: 80 / but I can’t see the image of the cameras.
Has anyone got it?
I assume that’s a typo?
If I’m sorry I wrote it wrong, I wanted to put http://
Hello pouvais vous donner les librairie pour esp32-cam car je n’es pas OV2640.h
