after a small tantrum this morning and getting very close to giving up on this project completely, i can now report that i am now successful
after failing for about a week with various codes salvaged throughout the web, i found a timelaps code this morning that had everything neatly set out in little functions,it was set to take a picture and save to SD card on a timed interval. i just deleted it and put the command on a virtual button. i just had to add the libraries and the blink write and connect it to the capture command, it now takes photos and saves them to sd card on command,
here is the working code, this just add your button on V3 on the app. add your wifi details in the code, upload and away you go
#include <WiFi.h>
#include <WiFiClient.h>
#include "Arduino.h"
#include <BlynkSimpleEsp32.h>
// Time
#include "time.h"
#include "lwip/err.h"
#include "lwip/apps/sntp.h"
// MicroSD
#include "driver/sdmmc_host.h"
#include "driver/sdmmc_defs.h"
#include "sdmmc_cmd.h"
#include "esp_vfs_fat.h"
// Edit ssid, password, capture_interval:
const char* ssid = "MYwifiID";
const char* password = "PASSWORD";
char auth[] = "BLYNK AUTH CODE";
int capture_interval = 5000; // microseconds between captures
long current_millis;
long last_capture_millis = 0;
static esp_err_t cam_err;
static esp_err_t card_err;
char strftime_buf[64];
int file_number = 0;
bool internet_connected = false;
struct tm timeinfo;
time_t now;
// CAMERA_MODEL_AI_THINKER
#define PWDN_GPIO_NUM 32
#define RESET_GPIO_NUM -1
#define XCLK_GPIO_NUM 0
#define SIOD_GPIO_NUM 26
#define SIOC_GPIO_NUM 27
#define Y9_GPIO_NUM 35
#define Y8_GPIO_NUM 34
#define Y7_GPIO_NUM 39
#define Y6_GPIO_NUM 36
#define Y5_GPIO_NUM 21
#define Y4_GPIO_NUM 19
#define Y3_GPIO_NUM 18
#define Y2_GPIO_NUM 5
#define VSYNC_GPIO_NUM 25
#define HREF_GPIO_NUM 23
#define PCLK_GPIO_NUM 22
Blynk.begin(auth, ssid, password);
if (init_wifi()) { // Connected to WiFi
internet_connected = true;
Serial.println("Internet connected");
init_time();
time(&now);
setenv("TZ", "GMT0BST,M3.5.0/01,M10.5.0/02", 1);
tzset();
camera_config_t config;
config.ledc_channel = LEDC_CHANNEL_0;
config.ledc_timer = LEDC_TIMER_0;
config.pin_d0 = Y2_GPIO_NUM;
config.pin_d1 = Y3_GPIO_NUM;
config.pin_d2 = Y4_GPIO_NUM;
config.pin_d3 = Y5_GPIO_NUM;
config.pin_d4 = Y6_GPIO_NUM;
config.pin_d5 = Y7_GPIO_NUM;
config.pin_d6 = Y8_GPIO_NUM;
config.pin_d7 = Y9_GPIO_NUM;
config.pin_xclk = XCLK_GPIO_NUM;
config.pin_pclk = PCLK_GPIO_NUM;
config.pin_vsync = VSYNC_GPIO_NUM;
config.pin_href = HREF_GPIO_NUM;
config.pin_sscb_sda = SIOD_GPIO_NUM;
config.pin_sscb_scl = SIOC_GPIO_NUM;
config.pin_pwdn = PWDN_GPIO_NUM;
config.pin_reset = RESET_GPIO_NUM;
config.xclk_freq_hz = 20000000;
config.pixel_format = PIXFORMAT_JPEG;
//init with high specs to pre-allocate larger buffers
if (psramFound()) {
config.frame_size = FRAMESIZE_UXGA;
config.jpeg_quality = 10;
config.fb_count = 2;
config.frame_size = FRAMESIZE_SVGA;
config.jpeg_quality = 12;
config.fb_count = 1;
// camera init
cam_err = esp_camera_init(&config);
if (cam_err != ESP_OK) {
Serial.printf("Camera init failed with error 0x%x", cam_err);
return;
// SD camera init
card_err = init_sdcard();
if (card_err != ESP_OK) {
Serial.printf("SD Card init failed with error 0x%x", card_err);
return;
bool init_wifi()
int connAttempts = 0;
Serial.println("\r\nConnecting to: " + String(ssid));
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED ) {
delay(500);
Serial.print(".");
if (connAttempts > 10) return false;
connAttempts++;
return true;
void init_time()
sntp_setoperatingmode(SNTP_OPMODE_POLL);
sntp_setservername(0, "pool.ntp.org");
sntp_init();
// wait for time to be set
time_t now = 0;
timeinfo = { 0 };
int retry = 0;
const int retry_count = 10;
while (timeinfo.tm_year < (2016 - 1900) && ++retry < retry_count) {
Serial.printf("Waiting for system time to be set... (%d/%d)\n", retry, retry_count);
delay(2000);
time(&now);
localtime_r(&now, &timeinfo);
static esp_err_t init_sdcard()
esp_err_t ret = ESP_FAIL;
sdmmc_host_t host = SDMMC_HOST_DEFAULT();
sdmmc_slot_config_t slot_config = SDMMC_SLOT_CONFIG_DEFAULT();
esp_vfs_fat_sdmmc_mount_config_t mount_config = {
.format_if_mount_failed = false,
.max_files = 1,
sdmmc_card_t *card;
Serial.println("Mounting SD card...");
ret = esp_vfs_fat_sdmmc_mount("/sdcard", &host, &slot_config, &mount_config, &card);
if (ret == ESP_OK) {
Serial.println("SD card mount successfully!");
Serial.printf("Failed to mount SD card VFAT filesystem. Error: %s", esp_err_to_name(ret));
static esp_err_t save_photo_numbered()
file_number++;
Serial.print("Taking picture: ");
Serial.print(file_number);
camera_fb_t *fb = esp_camera_fb_get();
//char *filename = (char*)malloc(21 + sizeof(int));
char *filename = (char*)malloc(21 + sizeof(file_number));
sprintf(filename, "/sdcard/capture_%d.jpg", file_number);
Serial.println(filename);
FILE *file = fopen(filename, "w");
if (file != NULL) {
size_t err = fwrite(fb->buf, 1, fb->len, file);
Serial.printf("File saved: %s\n", filename);
Serial.println("Could not open file");
fclose(file);
esp_camera_fb_return(fb);
free(filename);
static esp_err_t save_photo_dated()
Serial.println("Taking picture...");
time(&now);
strftime(strftime_buf, sizeof(strftime_buf), "%F_%H_%M_%S", &timeinfo);
char *filename = (char*)malloc(21 + sizeof(strftime_buf));
sprintf(filename, "/sdcard/capture_%s.jpg", strftime_buf);
if (file != NULL) {
fclose(file);
free(filename);
void save_photo()
if (timeinfo.tm_year < (2016 - 1900) || internet_connected == false) { // if no internet or time not set
save_photo_numbered(); // filenames in numbered order
save_photo_dated(); // filenames with date and time
BLYNK_WRITE(V3) {
int pinValue = param.asInt();
if (pinValue == 1) {
save_photo(); } // change to save_photo_numbered(); if you would like dated filenames
final note. i couldn’t get the led to turn off between image captured, any attempt to turn it off, stopped the image being captured some how. i will design it in as a standby light…
next mission, add a visual display of the camera to blynk,
