hi everyone I need your help with my project.
I have esp32 connected with ORP sensor and I did the coding after I finished compiling the code and I press on the monitor serial in Arduino it shows error in this message ((Board at COM4 is not available)) also in Blynk show that the ORP sensor not online thank you
//libraries
//pH and ORP variables
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
#define samplingInterval 10 //sample values every 10 milliseconds
#define ORP_Pin 1 //orp meter output,connect to Arduino controller ADC pin
#define ORP_OFFSET 98 //zero drift voltage
#define arrayLenth 40 //times of collection
char auth[] = "xxxxxxxxxxxxxxxxxxxxxxxxx";
char ssid[] = "Mashi";
char pass[] = "mashithah";
double ORP_Value;
int ORP_Array[arrayLenth];
int ORP_ArrayIndex=0;
int data_point_counter=0;
//general variables
#define voltage 3.30 //system voltage
#define printInterval 800 //write values every 800 milliseconds
//general formula returning average
double avergearray(int* arr, int number){
int i;
int max,min;
double avg;
long amount=0;
if(number<=0) {
printf("Error number for the array average!/n");
return 0;
if(number<5) { //less than 5, calculated directly statistics
for(i=0; i<number; i++)
amount+=arr[i];
avg = amount/number;
return avg;
}else{
if(arr[0]<arr[1]) {
min = arr[0]; max=arr[1];
else{
min=arr[1]; max=arr[0];
for(i=2; i<number; i++) {
if(arr[i]<min) {
amount+=min;
min=arr[i];
}else {
if(arr[i]>max) {
amount+=max;
max=arr[i];
}else{
amount+=arr[i];
avg = (double)amount/(number-2);
return avg;
Serial.println("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, pass);
int wifi_ctr = 0;
while (WiFi.status() != WL_CONNECTED)
delay(500);
Serial.print(".");
static unsigned long GENERAL_printTime = millis();
ORP_Value=((30*(double)voltage*1000)-(75*avergearray(ORP_Array, arrayLenth)*voltage*1000/1024))/75-ORP_OFFSET;
if(millis() - GENERAL_printTime >= printInterval) //print to serial monitor and write to file
Serial.print(millis()/1000);
Serial.print(" sec -- ");
Serial.print("ORP value: ");
Serial.print((int)ORP_Value);
Serial.print(" mV -- ");
GENERAL_printTime=millis();
