Esp 8266 failing to connect (but only on some templates!)
I’ve connected my esp8266 through wifi just fine with the quickstart, but it doesn’t work (repeated:
Connecting to
[4307] Connected to WiFi
[4307] IP: 192.168.0.101
[4307]
___ __ __
/ _ )/ /_ _____ / /__
/ _ / / // / _ / '/
//_, /////_
__/ v1.0.1 on ESP8266
[4384] Connecting to blynk.cloud:80
[4969] Redirecting to fra1.blynk.cloud:80
[4970] Connecting to fra1.blynk.cloud:80
and start over again)
the issue is that, other than BLYNK_TEMPLATE_ID, BLYNK_DEVICE_NAME, BLYNK_AUTH_TOKEN, on the same device, it connects when using the quick start template (and goes to “ready”), but not when using other templates (where it repeats this segment. I’ve narrowed the code to the bare minimum, so it should do nothing but connect. and they are the same, why one works and the others don’t?
//here are the def etc..
BLYNK_CONNECTED()
Please post your full sketch, and clarify exactly what this means…
full sketch (sensitive info redacted), it’s the same when working and when not working, besides BLYNK_TEMPLATE_ID, BLYNK_DEVICE_NAME, BLYNK_AUTH_TOKEN, once copied from the device page when creating new device from template (not working) and once when creating new device from quickstart (working):
#define BLYNK_TEMPLATE_ID REDACTED
#define BLYNK_DEVICE_NAME REDACTED
#define BLYNK_AUTH_TOKEN REDACTED
char ssid[] = REDACTED;
char pass[] = REDACTED;
// This function is called every time the device is connected to the Blynk.Cloud
BLYNK_CONNECTED()
  // Change Web Link Button message to "Congratulations!"
  Blynk.setProperty(V3, "offImageUrl", "https://static-image.nyc3.cdn.digitaloceanspaces.com/general/fte/congratulations.png");
  Blynk.setProperty(V3, "onImageUrl",  "https://static-image.nyc3.cdn.digitaloceanspaces.com/general/fte/congratulations_pressed.png");
  Blynk.setProperty(V3, "url", "https://docs.blynk.io/en/getting-started/what-do-i-need-to-blynk/how-quickstart-device-was-made");
// This function sends Arduino's uptime every second to Virtual Pin 2.
void myTimerEvent()
  Blynk.virtualWrite(V2, millis() / 1000);
what I mean by not working:
in the device page it goes online-offline in alteration constantly and on the serial monitor I see
[4307]
    ___  __          __
  / _  / / // / _ \/  '_/
 /____/_/\_, /_//_/_/\_\
        /___/ v1.0.1 on ESP8266
[4831] Redirecting to fra1.blynk.cloud:80
[4833] Connecting to fra1.blynk.cloud:80
⸮⸮⸮Ԝ[71] Connecting to REDACTED
on repeat every 30 seconds.
In the quick start version the last line is
[5052] Ready (ping: 85ms).
BLYNK_CONNECTED()
void myTimerEvent()
[4307]
    ___  __          __
In the quick start version the last line is (with no repeat)
