Esp 32 won't send sensor values to Blynk App
Hello!
I have been trying to work on a home automation project using Blynk. However, it seems I have been unable to properly read sensor values to be sent to the Blynk app.
Here the code I’ve been using to read a moisture sensor
//HERE THE LIBRARIES ARE INCLUDED
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
//HERE THE BLYNK AUTHENTICATION TOKEN IS ADDED
char auth[] = "90ca360db7a********************";
char ssid[] = "*****";
char pass[] = "*************";
//DEFINE BLYNK TIMER
//DECLARATION OF VARIABLES
#define sensor 26
int value;
  timer.setInterval(1000, sendvalue);
  pinMode(sensor, INPUT);
void sendvalue(){
  value = analogRead(sensor);
  value = map(value, 1, 4095, 1, 100);
  Blynk.virtualWrite(V5, value);
  Serial.println(value);
So what is the problem you face exactly?
It just keep reading a maximum β€œ100”
Seems like it never actually reads the values.
Try adding in some more serial print statements to see the readings before you map them.
Tried that, still won’t read the values.
It keeps reading β€œ4095” before mapping, and β€œ100” after mapping.
I think you need to use a different pin.
https://docs.espressif.com/projects/esp-idf/en/latest/api-reference/peripherals/adc.html
Try GPIO pins 32-39, that is the ones connected to ADC1, as ADC2 cannot be used when using wifi.
Tried this, worked like a charm!
Thanks a thousand.
