Hello, I just did this code can you tell me the problem. thank you so much
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
#include <OneWire.h>
#define ONE_WIRE_BUS 2 // Your ESP8266 pin (ESP8266 GPIO 2 = WeMos D1 Mini pin D4)
char auth[] = "XXXXX";
char ssid[] = "XXXXX";
char pass[] = "XXXX";
int roomTemperature; // Room temperature in F
sensors.begin(); // Starts the DS18B20 sensor(s).
sensors.setResolution(10); // More on resolution: http://www.homautomation.org/2015/11/17/ds18b20-how-to-change-resolution-9101112-bits/
timer.setInterval(2000L, sendTemps);
// to avoid delay() function!
void sendTemps()
sensors.requestTemperatures(); // Polls the sensors.
roomTemperature = sensors.getTempFByIndex(0); // Stores temperature. Change to getTempCByIndex(0) for celcius.
Blynk.virtualWrite(1, roomTemperature); // Send temperature to Blynk app virtual pin 1.
