ESP-12E I/O question
Hi
I understand that while uploading a program to the ESP-12e to use stand alone that I have to pull I/O 0 low while I press reset and also that some pins should be held high but once the program is loaded , and all I want to do is run it
How many I/Os can I use and which ones are theyfor example , someone told me I can use I/O 16 but only as an output
not an input .
So which ones can I use as inputs/outputs or both .
I am hoping I can use 8 as I have an 8 channel relay board that I want the ESP to control
Regards
Don
I think your question is not related to Blynk. So I would recommend doing these things:
  • make sure you can flash Blynk to your hardware
  • find out how to enable many pins on ESP. There should be lots of info online
  • get back to Blynk and use Virtual Pins to control relays
Hi Pavel
Sorry for asking in the wrong forum. I have been playing with Blynk and an ESP board and just think
of them as my IOT kit, I forget they are 2 seperate systems and I would have been better
to ask on the ESP forum
I have been using Blynk with a small ESP-01 board and it works fine tuning on and off 2 relays
I had seen another post on this forum about the larger ESP-12 which I just ordered and thought maybe some one
on here might have been able to answer my question
But no worries , I will ask on the other forum
Love your Blynk app , its magic
Don
It would be great if some Blynker could help you, anyways! Good luck
Just for info…
I am using an ESP 12E…
pins I can control are …
0,2,4,5,12,13,14,15 and 16! plus adc. (16 just digital output)
Not too bad for the 2 dollars they cost me!
Hi Roffey,
I have similar setup with lolin wemos board (£4 but with ready to plug USB interface, really cheap). The only problem I have is that I need to keep calling Blynk.run() after every Blynk.[operation], so it does not keep disconnected. Do you have similar problem? I use about 7 virtual pins, 4 to report values back to the Apps.
Thanks.
As yet I have not had any disconnection issues.
I do use virtual pins with the calls in setup().
I just started with a basic example and expanded from there.
Although in the loop there exists the Blynk.run, as the example provided, so I assume that is the reason.
I am still awaiting the instructions for pasting code, so I’m afraid I have just pasted it.
yield();
Hi Pavel !
How I can send a notification (email or widget notify) from code on esp8266 to the web server ?
I try code “Blynk.email("my_email@example.com”, “Title”, “Body”);" but it not work, becouse its code for widget.
дравствуйте Павел ! Каким образом я могу отправить уведомление (например емайл) из кода
для esp8266 на вебсервер, в данном случае облако ?
Смысл процедуры , в настройке уведомлений по достижению значению параметра ()
не хочется пересобирать ваше приложение для андроид, пусть лучше это будет в коде проекта для ESP8266
Заранее вам благодарен !
@stanislav_labs
You are hijacking the thread, please create a new topic.
