Esp-01 with relay
Hello
excuse me I’m using esp-01 to control relay through blynk and also has humidity sensor
previously i use it with old version of blynk and it was working fine.
but after i changed to the new blunk 2.0 , it doesn’t work properly … i can get data from humidity sensor on … but i cant control the relay with switch button in blynk like i used to
this is my code
#include <DHT.h>
char auth[] =
char ssid[] =
char pass[] =
#define DHTPIN 2
#define DHTTYPE DHT11
DHT dht(DHTPIN, DHTTYPE);
void sendSensor()
  float h = dht.readHumidity();
  if (isnan(h) || isnan(t)) {
    return;
  Blynk.virtualWrite(V5, h);
  Blynk.virtualWrite(V6, t);
  Serial.print("Temp = ");
  Serial.print(t);
  Serial.print(" Humi = ");
  Serial.println(h);
  //pinMode(3, OUTPUT);
  Blynk.begin(auth, ssid, pass, "blynk.cloud",80);
  dht.begin();
BLYNK_WRITE(V4)
  // button was pressed
  if (param.asInt() == 1)
    digitalWrite(3, HIGH);
    timer.setTimeout(60000L, relayOff);
void relayOff()
  digitalWrite(3, LOW);
the relay most be open for 1 minutes the back to normal
I’d really appreciate your help
thank you
First of all, you shouldn’t be forcing the connection to t6he new Blynk IoT servers like this;
Instead you should be using:
and placing the BLYNK_TEMPLATE_ID and BLYNK_DEVICE_NAME at the very top of your sketch and compiling the sketch using version 1.1.0 of the Blynk C++ library.
Secondly, you need a pinMode() statement in your void setup to declare the relay pin (GPIO3) as an OUTPUT.
